Engine running too warm
brit vw boy
PostPosted: Wed Mar 09, 2005 5:56 pm    Post subject: Engine running too warm Reply with quote
Engine runs too warm (though the temp gauge only shows the needle half way up the gauge )
and when i stop after a half hour drive, the engine chucks about a litre of coolant on to the floor.
I cant see where this coolant comes from but it appears to be somewhere near the bottom left corner of the radiator ?
any ideas guys ? ?
PS smoothie, the regulator/alternator is running a dream, thanks !
1959 vw type 2
1986 Porsche 924 S
1981 porsche 924 fh lux - FOR SALE
PostPosted: Wed Mar 09, 2005 7:25 pm    Post subject: Reply with quote
Check your coolant tank cap.
Make sure you are not over filling the system.
Have you bled the system recently?
Roger
PostPosted: Thu Mar 10, 2005 1:16 pm    Post subject: Reply with quote
Agreed
1981 924 NA
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
PostPosted: Thu Mar 10, 2005 1:38 pm    Post subject: Reply with quote
One of your hoses could have a blow out & the system isnt pressurizing and doing its job so it over heats and chucks up coolant.
brit vw boy
PostPosted: Thu Mar 10, 2005 11:21 pm    Post subject: Reply with quote
Thanks again guys. (You are so helpfull on this forum.... Ok, thats for another thread.)
I changed the coolant cap for a new one. Bingo!
Thanks
1959 vw type 2
1986 Porsche 924 S
PostPosted: Fri Mar 11, 2005 6:27 am    Post subject: Reply with quote
Great news!
I would still bleed the coolant system to remove any air that may have entered the system. It only takes 5 minutes.
PostPosted: Fri Mar 11, 2005 8:41 am    Post subject: Reply with quote
I posted some misinformation about the temp gauga values.....
The centre gauge marker on the coolant reading actually corresponds to 95 degrees. So naturally when you shut off the engine after some driving time it rises to the point of boiling.
Proper running of this engine should be around the first marker.... or 85 degrees.... This will eliminate boil over at shutdown.
Look at a cooler thermo fan switch, and rewire the thermo fan without the resistor in it. This should cool things down much quicker after shutdown...
Leadfoot
speedsta2003
PostPosted: Sat Mar 12, 2005 3:04 am    Post subject: Reply with quote
another thing is you can buy a gauge at your local parts store or walmart that will tell you the mixture of your coolant and water. If it's not the correct mixture it may cause a lower boiling point or less efficient cooling.
My Old Porsche Thats Sold
http://members.cardomain.com/jatbballboy15
