Rear sway bar
dwak
PostPosted: Fri Aug 18, 2006 11:54 am    Post subject: Rear sway bar Reply with quote
Had the '81 931 up on the hoist today to see about installing a rear sway bar but found there was no provision for mounting the rubber bushing clamps like on my 924S and as per the manual. Anyone have some suggestions?
dwak
2x924NA's for parts
931
924S
gohim
PostPosted: Fri Aug 18, 2006 6:19 pm    Post subject: Reply with quote
You can either buy a u-bolt clamp kit like the one offered by Weltmeister (very expensive), or a generic kit from a auto parts store, or assemble your own u-bolt clamp kit from parts purchased from a hardware store.
dwak
PostPosted: Fri Aug 18, 2006 9:27 pm    Post subject: Reply with quote
Just as I thought. Strange that a 931 had no provision for it, though.
Thanks,
dwak
2x924NA's for parts
931
924S
-nick
PostPosted: Sat Aug 19, 2006 12:05 am    Post subject: Reply with quote
Hey Dwak (long time no see?!)
Are you saying that you don't have the mounts on your torsion bar carrier? That would definitely require something like the Welt kit. Or you can cut some off a torsion carrier that does have them and weld them onto yours. The Welt kit is very ill-fitting.
PostPosted: Sat Aug 19, 2006 1:07 am    Post subject: Reply with quote
7 to 13 pics starting here (depending on how many you feel like looking at) show the Weltmeister rear bar mounting -
http://pg.photos.yahoo.com/ph/smoothies931pics/detail?.dir=a7d5&.dnm=6e7c.jpg&.src=ph
To duplicate that, you'd need 3.5" U-bolts as shown in the second image. To copy the end link to car attachment, you could weld bolts to the existing camber eccentric bolts.
Mounts welded to the torsion bar carrier would be better than the U-bolts. If you do go with U-bolts, they'd be better tack welded to the t-bar carrier (something that's been on my own list to do for quite some time).
