Fuel Pressure sporadic, 82 931
Gregarious
PostPosted: Tue Jan 25, 2005 3:34 pm    Post subject: Fuel Pressure sporadic, 82 931 Reply with quote
Jes got home from the mechanix. 9pm since 6:30am. Tired. Anyways, the fuel pressure has begun to go from normal, to about 40, with no changes and no warning. Can't run on 40. And I didn't drive it home. New fuel pumps, new fuel filters, new injector sleeves. Latter is what we were doing. Any ideas? Thanx, D
A man is known by the friends he makes, and the enemies he keeps...
Want a womans attention? Ignore her...
Those who cannot do...teach!
PostPosted: Tue Jan 25, 2005 6:42 pm    Post subject: Reply with quote
My pressure was doing something similar as the fuel pump was going bad. -Fixed by replacing the main fuel pump.
Also make sure the flow direction arrow on the front fuel filter is pointing toward the rear. I'm not 100% sure this could be your problem, but have heard (read) that the innerds can shift and block the flow, so might as well check that it's on right.
CMXXXI
PostPosted: Wed Jan 26, 2005 3:51 am    Post subject: Reply with quote
Only other thing that comes to mind is the pressure regulator in the fuel distributor head. It is responsible for maintaining system-wide pressure. But, of course, if you pump isn't even generating it's "threshhold pressure", then it won't come into play. I'd suspect a bad pump first though.
'79 Eurospec 931
