Brake package...
Khal
PostPosted: Tue Aug 03, 2004 8:18 am    Post subject: Brake package... Reply with quote
Did all '81 Turbo's come with the five-bolt hubs? (ROW specifically)
Mine has five-bolt hubs but I know it's had a brake conversion. My option codes do not list the "M471" (?) option.
Just wondering if it might have originally had four-bolt hubs?
Also, I don't think mine are the standard brakes. The PO mentioned that it had brakes off another Porsche -could've sworn he said 911 but it might've been another. It was a long time ago, and although it sounded impressive at the time, I've since completely forgotten. The discs are very large (for a car of that age anyway, I know most modern performance cars have monster rotors) and the calipers have quick-release pads (like a racing car), is this normal for M471 conversion?
I do know the car used to be raced. Does anyone know what brakes off other Porsche models would fit my 924? I don't think the suspension has been modified greatly, if at all, except for better shocks and springs and it has been lowered. I think it's relatively normal because I bent a rear suspension arm and popped an axle (long story) but the mechanic got replacement parts off a normal 924 (Turbo or NA, not sure).
Any ideas?
'80 924 Turbo
CMXXXI
PostPosted: Wed Aug 04, 2004 3:13 am    Post subject: Reply with quote
No, not all 931 came with the 5-bolt brake setup, ROW or US. I think they became standard at some point (?81?82?) but don't know for sure. The brakes you describe "sound different" from the stock M471 setup though. I don't have my Turbo supplement here to check the specs on the brake components...
'79 Eurospec 931
Lizard
PostPosted: Wed Aug 04, 2004 1:00 pm    Post subject: Reply with quote
the M471 was optional equip on 79 and 80, in 81 it came standard on Turbo models, any chance of getting of photo of your brakes.
speaking of which I am going to start mounting the 928 brakes on my project car soon, cant wait
3 928s,
CMXXXI
PostPosted: Wed Aug 04, 2004 11:11 pm    Post subject: Reply with quote
I looked up the brake specs for you last night, here they are:
Stock front discs/rear drums:
Disc diameter: 257mm
Disc thickness: 13mm
M471 specs:
Diameter (F/R): 282.5/289.0
Thickness (F/R): 20.5/20.0
'79 Eurospec 931
