jpab924
Posted: Mon Jun 07, 2004 11:28 am Post subject: best way to tow a 924 |
| Do you guys think a car dolly is suitable for towing a 931, oh lets say roughly 80 miles? I`m trying to keep this move on the cheap and looking at u-haul trailers. Thanks..........jP |
924guy
Posted: Mon Jun 07, 2004 12:27 pm Post subject: |
dolly will work fine, as long as its not an automatic.. Ive dollied my 924's all over the country, with no special prep..no issues as a result... 80 miles should be a breeze..for longer distances its a good idea to keep an eye on the transaxle to make sure its not getting to hot.. some have disconnected the axels, but i never found it necessary..even on 900 mile plus tows.. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
crazyinkc
Posted: Tue Jun 08, 2004 12:43 am Post subject: |
| If you use a dolly, make sure the ramps will clear the rocker panels on the sides of the ramps. I used a friends dolly to tow a parts car and the rockers got smashed. just something to keep in mind. |
Posted: Tue Jun 08, 2004 9:15 am Post subject: |
I've used a dolly several times and a trailer a couple of times to move 924/944s.
I prefer the trailer, but the dolly is easier to do. Just don't try backing up with a dolly!
If your cv joints need to be serviced soon, remove the axles before using the dolly, otherwise just do it. |
