ProudGecko
Posted: Tue May 18, 2004 10:27 am Post subject: underbody coating |
anybody know of a good way to remove underbody coatings? I'm trying to strip it off a fuel tank if that makes any difference.
Thanks _________________ 1988 Porsche 924S
1986 Kawasaki Concurs ZG1000
1984 Mercedes 190D
1973 Honda CB500 |
Doodle
Joined: 25 Nov 2002 Posts: 225 Location: Comox Valley, B.C. Canada
Posted: Wed May 19, 2004 12:08 pm Post subject: |
Provided the tank is empty of fuel you might try a wire brush attached to a drill. If it's the original rubber type undercoating as on the rest of the under carriage the wire brush will work. If it's a cheap, imitation aftermarket product try brushing on varsol, gasoline or perhaps acetone. _________________ Doodle
Pre 77.5 Mars Red |
ProudGecko
Posted: Wed May 19, 2004 1:23 pm Post subject: |
yea I've been using the wire brush method and it is a pain, that stuff gets everywhere lol. _________________ 1988 Porsche 924S
1984 Mercedes 190D
1973 Honda CB500 |
AndyFranklin
Posted: Wed May 19, 2004 11:49 pm Post subject: |
A propane torch and putty knife works to get the bulk of it off. The smoke is a bit much, however. I suppose a heat gun might work instead of the torch.
Knotted wire cups work much better than straight ones. And cups on angle grinders even better. Still very, very messy and laborious.
That's why I'm going the dip route and getting rid of everything. |
Magnus K
Joined: 25 Oct 2003 Posts: 151 Location: Linkoping, in Sweden
Posted: Thu May 20, 2004 12:43 am Post subject: |
| AndyFranklin wrote: | | A propane torch and putty knife works to get the bulk of it off. The smoke is a bit much, however. I suppose a heat gun might work instead of the torch. |
Hey, using blow torch on a fuel tank??? I wouln't try that!
/Magnus _________________ Another curious Swede...
Asleep in Sweden, Europe, when you US guys are awake... |
AndyFranklin
Posted: Thu May 20, 2004 11:45 pm Post subject: |
Me, neither!
The fuel tank is out of my car and I zoned in on the "underbody"..... |
