Email: jfurst81@hotmail.com
Date: 10 Jul 2001
Time: 00:06:08<Now that I've shared, I need help getting my boost controller adjusted. It is the blue TurboX (turbonetics?) one. Right now I'm approaching 14PSI if I'm not careful. Lots of power, but not good for the car. I've tried adjusting the little screw in the middle of the thing but it doesn't seem to make a difference. Here is a pic. Is it on correctly? How do I turn the boost down? >
You don't have instructions for the unit? My MBC needs to be turned anti-clockwise to turn it to it's lowest level. Also, it needs to be pulled out before any adjustment is made, then it can be pushed in to lock it. Your unit might have the same type of safety feature. Are you sure you put the hose to the wastegate line on the right fitting?
Jon Furst
'81 931
