Dyno-tuning for my '81 924 Turbo
Khal
PostPosted: Mon May 08, 2006 1:22 pm    Post subject: Reply with quote
Thanks sequential,
sequential wrote:
I think you are reading into this too much, i'm not saying the car has cancer and it is cato, i was just evaluating your dyno sheet.
I know she's not a junker!
sequential wrote:
It is normal to see +/- .25-.5 psi when measured electronically , it wil give 3-6 bhp variation on the graph. Also most Dyno software has a smoothing feature that takes care of this so you get an average. you can next time ask the operator to do this or open the grids up , it all depends on how detail you would like the graph.
THe graph yes is smooth with the exception of the change after peak torque ( it appears ) but it is not always normal for the power to fall at the end , as at this boost power level you have not really started to extend the turbo, so trialing off is ususally from boost taper and or a very restrictive exhaust ( not likely until 1 bar ) but it is also possible the setup has started to fall after 6000 rpm ( i have never checked a stock 931 ) hence the roll off.
Yeah, that's the sort of thing I wasn't sure of. Experienced people know what to expect but there's very few dyno plots of 924 Turbos so I've got little to compare it to. And I don't personally know anyone who's had it done before ('cept Kenodog but his has been highly modified).
Not 100% sure I'm gonna put the boost controller on it yet. I've gotta talk to crunchie 57 and get his opinion. He's been into the engine, he knows what's what...
flosho wrote:
Nice Kahl... Any video?
Thanks but no video, unfortunately. From my previous post:
Khal wrote:
I couldn't vid the runs. Unfortunately, the dyno's setup in a warehouse-style workshop and it was just too dark to get a good picture (with my dodgy digicam)
flosho wrote:
Hopefully I'll be able to get some dyno time too...
Yeah, do it! It's cool
flosho wrote:
150 at 7.5 psi seems pretty good, considering stock US boost is 7 and we only have 155 crank hp.
I actually thought it might read higher. But I'm certainly not dissappointed! I'm rather impressed with the old girl!
'80 924 Turbo
Khal
PostPosted: Fri May 12, 2006 5:33 pm    Post subject: Reply with quote
Alrighty then... she's hittin' the dyno again tomorrow with 10psi
Anyone care to guess at the result?
'80 924 Turbo
tj924
PostPosted: Fri May 12, 2006 5:38 pm    Post subject: Reply with quote
BOOOOOOOOOMMMM!!!!!
TJ
Silver '82 924 NA 5-Speed Manual
Khal
PostPosted: Fri May 12, 2006 7:04 pm    Post subject: Reply with quote
BOOOOOOOOOMMMM!!!!!
*slow clap* Ha ha ha.
I was waiting for that one.
'80 924 Turbo
tj924
PostPosted: Sat May 13, 2006 9:33 am    Post subject: Reply with quote
Your welcome!
BTW, did you go with a new wastegate spring or did McGyver install the Boost Controller for you?
TJ
Khal
PostPosted: Sat May 13, 2006 1:15 pm    Post subject: Reply with quote
OK, so that didn't go as planned...
Nothing bad (car and engine-wise), just the boost controller didn't appear to be functioning correctly
She'd boost to 12psi -on my boost gauge, which is working properly, before anyone asks -then the overboost switch would cut in (and throw us through the windscreen ). We did a couple of runs down the street at various settings but no joy, same thing over and over, it just didn't want to play ball.
crunchie 57 suspects that a little rubber o-ring on the needle screw is buggered. He's gonna check it out later. But for now, no boost controller and the dyno session was cancelled
Oh well, on the plus side, it felt pretty good for that millisecond that it hit 12psi
Strange thing is that the overboost switch isn't supposed to cut in 'til 21psi, according to the manual (not that I was complaining, I don't think 21psi would've been too healthy for the engine!).
'80 924 Turbo
PostPosted: Sat May 13, 2006 1:50 pm    Post subject: Reply with quote
did you try it at max both ways? as sometimes they can be backwards.
3 928s,
PostPosted: Sat May 13, 2006 2:11 pm    Post subject: Reply with quote
The boost switch is more sensitive to quick changes in boost than your gauge witch is on the end of 2 or 3 foot hose.
It easy enough to check your switch's trip point by using your boost gauge, an ohm meter and a compressed air source.
PostPosted: Sat May 13, 2006 2:41 pm    Post subject: Reply with quote
I had a similar run in last week at the track.
I had installed a compressor pressure switch, and tried using that as a boost controller, but it was very finicky. I could crank on it, and it wouldn't change the boost, it would stay at 7 psi.. then all of a sudden if you turn it a bit more, it would boost 20 PSI. It was basically all or nothing.
I have now installed a plain "Manual boost controller"(search on ebay, very simple 8 dollar valve) and it was much easier to set the PSI, I took it out this morning at hit 12 psi and stayed steady... Pulls real nicely!
Khal
PostPosted: Sat May 13, 2006 3:31 pm    Post subject: Reply with quote
Actually, no. But I'm pretty sure it'd be right. crunchie 57 was using it for months before his engine popped. I'm guessing he had it the right way around. Still, maybe this'll be one of those "d'oh!" moments... I'll give a call and check.
Yeah, I suggested exactly that to crunchie 57. I figured it might be building boost quicker than the gauge could register it. He agreed it could be the case.
flosho wrote:
I have now installed a plain "Manual boost controller"(search on ebay, very simple 8 dollar valve) and it was much easier to set the PSI...
Yep, that's exactly the sort we were using. I'm sure they work a treat... when they work.
'80 924 Turbo
bass gt
PostPosted: Sat May 13, 2006 3:46 pm    Post subject: Reply with quote
Khal,
Very interesting mate. I've just had the exact same thing. She went back to the dyno after some bits and pieces, and suddenley, anything above stock boost was a pain. Spiking and the like. It seemed my valve is acting a bit strange. It's either stock boost or overboost!! So I've removed it now, and she is making a healthy 155 at the hubs at 10 psi, which equates to 175-180 crank.
However, I've just bought an GReddy EBC off EBay of a bargain, so I'm going to give that a try. I think controlling the wastegate from the top has to be better than restricting the actuator line to it.
I'll keep you posted.
Steve
Khal
PostPosted: Sat May 13, 2006 4:30 pm    Post subject: Reply with quote
bass gt wrote:
...and she is making a healthy 155 at the hubs at 10 psi, which equates to 175-180 crank.
Ah, it's nice to know I'm close to your power with only 7.5psi...
Cheers. Yeah, let us know what happens.
'80 924 Turbo
WEASEL149
PostPosted: Tue May 16, 2006 7:11 am    Post subject: Reply with quote
bass gt wrote:
Khal,
Steve
I've tried both ways and found that controlling the wastegate from the top is much better (and safer).
Restricting the actuator line can give you boost spikes. I had problems doing it that way.
I took a solid pipe from a union screwed into the top of the wastegate, up around the back of the engine and then ran a silicone hose from that to the valve controller.
I think the Greddy will have to be plumbed into the top of the wastegate anyway if it's anything like my Blitz Boost controller. Look out for a switch on the Greddy to set it for external wastegate operation - I think it has one like mine.
1979 UK 932
sequential
PostPosted: Tue May 16, 2006 4:36 pm    Post subject: Reply with quote
The turbo smart manual valve is the only one i have seen work correctly when connected in line with the wastegate. it is designed for such unlike standard valves which do not allow the pressure to bleed of in the control line creating an over pressure situation after a couple of seconds.
928 gts prototype
baby blue engine block
steam in 1,2,3,4 sometimes
cold star issues while on stands
112 whp with new 4 valve head and MIS 2
Kenodog
PostPosted: Wed May 17, 2006 4:24 am    Post subject: Reply with quote
Yep.I've got the TurboSmart two stage controller and it holds steady at any setting I choose.Never fails and it's nice to be able to tool around town at 9 psi then instanly switch to 13 psi to wipe the smiles off many a ricer's face. (Raced a 1990 Skyline the other day.I couldn't pass him but he sure was shocked to see my mug in the rearview no matter what he did.)
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Page 4 of 5
