Help me make sense of these CIS results — ’79 924 NA
Goto page Previous  1, 2, 3
coup85
PostPosted: Sun Sep 14, 2025 5:26 am    Post subject: Reply with quote
I know, I tried, but it's difficult to find the right point. At the moment seems like I have a lean problem during the cold start and a rich problem during the hot one???
With the WUR in range, the AAV discarded, as well as the CSV, although I feel I tested it ages ago when all these problems started, I think it might be something else, injectors leaking maybe? I don't know…
924 - 79'
Raize
PostPosted: Sun Sep 14, 2025 6:21 am    Post subject: Reply with quote
In that case you do need to adjust the "brass plug" on the WUR to reduce the cold control pressure. As I recall, 0.5 bar of WUR pressure is worth about 1 AFR. Unfortunately with K-Jet being an analog system, just being in range often is not enough.
Without a wideband gauge your only way of figuring out whether you're lean or rich is messing around with the mixture screw, so be methodical about it.
Cold start is entirely down to having a proper mixture but hot start issues are more difficult to deal with. Try to get it to a point where you have good cold start, reasonable cold idle and good hot idle. Then do cold start switch mod and just accept you need to give it throttle to get it started when hot.
coup85
PostPosted: Sun Sep 14, 2025 6:40 am    Post subject: Reply with quote
Thanks, Raize. It's exactly what I was thinking, the cold pressure it's kind of close, so I'm going to see if I can decrease the pressure a little over the diaphragm inside the WUR.
924 - 79'
Raize
PostPosted: Mon Sep 15, 2025 1:28 am    Post subject: Reply with quote
You'll get there eventually.
This is why my WUR is installed with only the top bolt though. You'll understand what I mean, I am sure.
Riggard
PostPosted: Mon Sep 15, 2025 4:29 am    Post subject: Reply with quote
#lifehack on the bottom bolt of the wur; take a much longer bolt, thread a nut on It with loctite at approx the same distance/length as the original bolt. Now when it dries, you can put the new longer bolt in much easier and still tighten it.
coup85
PostPosted: Mon Sep 15, 2025 4:43 am    Post subject: Reply with quote
Thank you both, @Riggard, indeed I have two threaded rods there, top and bottom –fixed with blue Loctite, which makes it much easier to install/remove the WUR.
924 - 79'
Beartooth
PostPosted: Tue Sep 16, 2025 2:26 am    Post subject: Reply with quote
coup85 wrote:
Update: after a little research, it appears that the plug was for protection, as the air coming from that hole passes through the plate, missing the filter, but not causing a leak by itself, as is metered by the sensor plate. So, time to check somewhere else!
Are you sure about that? I was going to post earlier and forgot about it. If it's like the 931, the adjustment hole needs to be sealed - otherwise you have "false air." That is, air that enters without passing the air flow plate, and will have the effect of leaning the mixture. I think the 931 had a similar rubber plug - mine was long gone when I got the car. All I did was to drill and tap it for a short bolt to act as a plug, so that's one option. Another would be to find a rubber plug at a hardware store. Does the idle change if you block the hole? If not, then it must be different, but on the 931 you definitely wouldn't want to run around without it.
1980 931 diamond in the rough
coup85
PostPosted: Tue Sep 16, 2025 3:18 am    Post subject: Reply with quote
The truth is, the lack of information about it worries me a little. I found a couple of people talking about it. I can only find one, but both were talking about the same:
https://forums.pelicanparts.com/porsche-911-technical-forum/403786-plugging-cis-mixture-adjustment-hole.html
924 - 79'
Raize
PostPosted: Tue Sep 16, 2025 3:36 am    Post subject: Reply with quote
The 931 having a downdraft air flow meter means the hole allows the air to enter after the metering plate.
The 924 has an updraft air flow meter so the air enters before the metering plate and doesn't really matter (apart from that it bypasses the filter, which is not ideal, but wouldn't affect mixture.
Beartooth
PostPosted: Thu Sep 18, 2025 6:10 am    Post subject: Reply with quote
Oh, that makes sense then. I knew the regular 924 was updraft, but didn't realize the set screw could be somewhere you could access it without introducing false air; I haven't worked on a standard 924 yet. I was also thinking that way since he said the idle changed when he sprayed brake cleaner in it, but actually, that's expected whether it goes past the air flow plate or bypasses it.
Page 3 of 3
