bass gt
Posted: Sun Jan 14, 2007 9:23 am Post subject: |
Flosho,
Seems strange they are out of stock. Last time i spoke to them, a couple of months ago, they had them in and never mentioned them being an end of life item. Have you spoken to anybody at the factory?? If i can find the contact details of the guy i deal wwith, i'll pass it on.
Steve |
Min
Posted: Sun Jan 14, 2007 9:43 am Post subject: |
| bass gt wrote: | I have the Piper followers in my engine. Once they are shimmed up, you're good to go. No need to reshim after a run in, as long as good quality shims have been used.
Regarding the weight issue, they really are super light, but be careful as to their fitment intot he valve sockets. I had to have my follower sockets bored a fraction as the clearences were too tight. As for running the cam in, just run the engine at 2000rpm for 20-30 minutes, and you should be set.
Regards,
Steve |
according to my instructions from integral, you need to run the camshaft in at a different valve clearance than what you run it at after the cam has been run in. So you would in fact have to change the shims.
Min
Posted: Sun Jan 14, 2007 9:44 am Post subject: |
| bass gt wrote: | | Seems strange they are out of stock. Last time i spoke to them, a couple of months ago, they had them in and never mentioned them being an end of life item. Have you spoken to anybody at the factory?? If i can find the contact details of the guy i deal wwith, i'll pass it on. |
Last time I talked to them, they were out of stock and had no idea when they intended to make more. If they are in stock now, let me know, I need to order a set.
Min
Posted: Sun Jan 14, 2007 9:52 am Post subject: |
| Quote: | Set the initial cold valve lash at .011" intake/.011" exhaust. After the initial break-in period is over(see below), check the hot valve lash. Allow the motor to cool down and then adjust the cold lash by your measured cold-to-hot delta so that the valve lash will grow to .015" when your engine is hot. It is the hot valve lash that really matters.
Break-in the new cam at 2000 rpm or slightly higher for 20 minutes continously after the motor is first started with the new cam. |
from the instructions that came with both my integral camshafts.
