stevekat
Joined: 19 Jan 2008 Posts: 719 Location: Los Angeles, CA
Posted: Sat Nov 29, 2008 9:29 am Post subject: |
| Paul, thanks for those photos of the fuse box connectors. |
stevekat
Posted: Sun Nov 30, 2008 9:10 pm Post subject: |
| Regarding the fuel pump running momentarily when the car is off and the ignition switch is turned to run, using the KAE 433 906 059 fuel pump relay, with the KAE number 3.300.300 on a 1981 931, the pump does seem to run momentarily when the car has been off for a while, but if one shuts the car off, and then turns the ignition switch back to run, the pump does not run momentarily. Might have to do with a capacitor in the relay having to drain off before that cycle runs, or something along those lines. |
Maybe924
Joined: 14 Aug 2007 Posts: 412 Location: New London, CT
Posted: Mon Dec 01, 2008 5:00 am Post subject: |
I've got a different relay and it definitely does not prime the pump before starting.
I purchased it from Performance Products:
On the box it shows this part number:
931.615.113.00
On top of the relay itself it shows:
896481
SHO
W-Germany
Where did you get your relay? Is it 931 specific? _________________ 1981 931 GT (CGT Intercooled)
1985 911 Targa Carrera (Sold) |
Posted: Mon Dec 01, 2008 5:19 am Post subject: |
| stevekat wrote: | | Regarding the fuel pump running momentarily when the car is off and the ignition switch is turned to run, using the KAE 433 906 059 fuel pump relay, with the KAE number 3.300.300 on a 1981 931, the pump does seem to run momentarily when the car has been off for a while, but if one shuts the car off, and then turns the ignition switch back to run, the pump does not run momentarily. Might have to do with a capacitor in the relay having to drain off before that cycle runs, or something along those lines. |
On my 80 931 the pump runs briefly every time the ignition is turned off/on. I use this to overcome the hot start issue. _________________ White 87 924S "Ghost"
Maybe924
Posted: Mon Dec 01, 2008 5:25 am Post subject: |
OK I found the relay part number you have on Pelican parts but it doesn't show that its for a 931. Also it doesn't show that its 16A. Are you sure its the right relay?
I'd like to get a relay that primes my pump again, since it takes a good 3 extra cranks to get the car started without the priming function. _________________ 1981 931 GT (CGT Intercooled)
stevekat
Posted: Mon Dec 01, 2008 5:38 am Post subject: |
The relay you have is the factory spec relay with the rpm over-limit protection. The rev-limiter is built into the fuel pump relay on these cars, at least the 1981 and on, DITC ignition equipped vehicles.
Your 931.615.113.00 relay is rather expensive, something like $110 - $160, and hard to find. From the posts on the board, and other sources, the 433 906 059 relay is too, a 16A relay, made for two fuel pumps (one primary and one in tank.) So it can handle the current. It does not include the over-limit feature. These relays cost about $18 to $22, at least the generic ones from KAE, their part number 3.300.300, a big difference.
In installing mine and getting my system back to normal, I tested the relay and it works as advertised. It requires the pulse from the ignition and shuts down if the pulse is absent. It doesn't always prime the fuel pump, but seems to usually do so after the car has been off a while, I assume something in the relay itself, related to a capacitor discharging or something along those lines. I'll report back on this if I can discern why it does not always run the pump momentarily.
Did your old relay prime the pump? If so, maybe the replacement you ordered from Pelican is not an exact factory equivalent part, and behaves slightly differently, though it functions reasonably well.
Might as well order the 433 906 059 and see how it works. The cost is reasonable enough. And this way you'll have a spare with you in case your OEM relay gives up. If the newer relay works like you want (runs the pump momentariy,) you can keep your OEM relay as the spare. Either way you are in good shape.
Pelican doesn't list them for the 931 because it is not made for this car, though many owners use them.
It is a good idea to keep a spare relay. Even this rather generic relay was not in stock at any stores in my area. Probably a next day order. Easy to get stuck somewhere without one, thought you could jumper the terminals in the relay block in an emergency, at your own risk.
One item, make sure you turn the key to run, all the way, to make sure the circuit that powers the relay is on...if you stop a bit short, the circuit might not activate. |
Maybe924
Posted: Mon Dec 01, 2008 6:14 am Post subject: |
I'll certainly give it a try. _________________ 1981 931 GT (CGT Intercooled)
Maybe924
Posted: Tue Dec 09, 2008 11:42 am Post subject: |
IMPORTANT UPDATE:
I received the alternative Fuel Pump Relay (433 906 059) in the mail today. I popped it in and low and behold it fixed my hard start problem AND my dipping idle problem!
This is a fairly big deal in that I've been spending months trying in vain to diagnose and fix these two issues. I actually had purchased a new fuel pump relay this past summer from Performance Products. It was part no. 931.615.113.00. I was replacing my original fuel pump relay which had finally kicked the bucket. The replacement relay did manage to get the car started but it didn't prime the fuel pump with the key in the on position, it now took 5 cranks to start the engine and then I had a problem with the idle dipping. Thinking the first one might be faulty I purchased another but after receiving and installing another of the 931.615.113.00 relays I was still experiencing the same problems.
What confused the diagnosis is that at the time when the original fuel pump relay bit the dust I was in the process of fixing some vacuum leaks, and a fuel pump issue. I just couldn't tell which came first, or what caused what.
Over the past few months I've checked the cold start valve, the thermo-time switch and the AAV. I've checked and double checked for vacuum leaks. I've tested voltages and replaced my upper charge tube in place of the CGT intercooler... just in case it wasn't getting a good seal.
And then BAM... I pop in this alternative fuel pump relay part no. 433 906 059, and my problems go away. It started before the second turn and my dipping idle is history.
On top of that this fuel pump is only $18 at Pelican Parts.
I wonder how many 931s are running like crap because of their $104 "OEM" fuel pump relay 931.615.113.00??? _________________ 1981 931 GT (CGT Intercooled)
Buwani 931
Joined: 31 May 2004 Posts: 308 Location: Napa California
Posted: Tue Dec 09, 2008 3:31 pm Post subject: |
Cool, so the(433 906 059) does prime first?
Shawn _________________ 1980 931
That's thirty minutes away. I'll be there in ten. |
stevekat
Posted: Tue Dec 09, 2008 5:54 pm Post subject: |
Glad this worked out so well for you. My 433 906 059 does not prime every time - would be interested in your experience...mine usually primes if the car has been off a while. I am getting in a spare and shall see if that unit behaves differently in this regard.
Interesting how chasing these problems is a black art.
BTW, can you elaborate on dipping idle? Does it fluctuate up and down, etc. What symptoms? |
Maybe924
Posted: Wed Dec 10, 2008 1:53 am Post subject: |
| Buwani 931 wrote: | Cool, so the (433 906 059) does prime first?
Shawn |
Yes the (433 906 059) unit primes first, the "OEM" replacement unit does not.
Also, I'm assuming that my idle problem was caused by too low voltage getting to my fuel pump, suggesting the "OEM" relay has too much resistance.
Regarding the dipping idle. After the car warmed for about a minute, every time I goosed the throttle and raised the RPMs the idle would then drop down very low around 200-400 rpms then the DITC would adjust timing and bring the idle up to 800 rpms. I'm chalking this up to too much resistance in the "OEM" fuel pump relay. This would cause the fuel pressure to be too low and in turn reduce my idle and likely have the car running lean throughout its rev range. Also, the low voltage would effect the power of the cold start valve causing it to provide less fuel to the cold engine than it should. The AAV and WUR would also receive less voltage than normal and would modulate at a slower rate causing less than optimum warm up.
The thing that concerns me is whether I got a bad lot of the "OEM" relays or whether the entire design of the "OEM" replacement relays is faulty. The latter would have anyone replacing a burned out original relay suddenly chasing their tails with strange running and starting problems.
So to be clear. The $18 (433 906 059) relay also delivered as part no. KAE number 3.300.300, completely solved my starting and running issues I've been having since summer. These relays are available from Pelican Parts.
Also if you've replaced your relay with the "OEM" unit from Performance Products and find yourself having starting, idle and/or running issues, try using a jumper in place of the relay and if your problems go away you'll know the culprit. _________________ 1981 931 GT (CGT Intercooled)
stevekat
Posted: Wed Dec 10, 2008 3:49 am Post subject: |
| Does your relay prime every time, ie: if you turn off the car, and then within a few seconds turn the key back to the run position before starting, does it prime again? My car does not prime every single time the key is turned from off to run - my system seems to be contingent on how long the car is off, or some other variable. Would like to get some baseline. |
McGyver
Joined: 24 Feb 2009 Posts: 354 Location: Jelenia Gora - Poland
Posted: Sat Feb 16, 2013 2:17 pm Post subject: |
Regarding to this scheme:
elements:
capacitor on 5 - 1.5uF - in KAE you got 1nF
resistor between 6,7 and 4 - 620k on scheme and 0,6M in KAE
If you know how NE555 work that elements in KAE gives power to fuel pump just for 0,6s. So I think changing this two elements will change time which powers fuel pumps...
So...
Original relay powers fuel pumps about 1sec
KAE makes it for about 0,6sec
I don't know what is original time in 931 relay (I'm not sure that on scheme is correct) but I think we can change it to ~3 to 4 seconds and that will be enough to make good fuel pressure to start.
Does anyone try this way to solve that problem? _________________ 931 82' - 5000km after full engine rebuild
www.mauser98k.internetdsl.pl - if someone like german rifles (English version avalible) |
Posted: Sat Feb 16, 2013 5:55 pm Post subject: |
i knew that ß555 can provide different temporizator intervals ? _________________ Supercharger and EFI kits
https://www.the924.com |
stevekat
Posted: Sat Feb 16, 2013 6:12 pm Post subject: |
I think it would be nice to be able to set a custom time for the fuel pump relay to prime the system.
Mine does not prime each time however. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's. |
