Posted: Thu Feb 08, 2007 3:57 pm Post subject: |
I think I've made a decision..
225/50/16 and 205/55/16
Fuzion ZRi. _________________ [This Space For Rent] |
ic932
Posted: Thu Feb 08, 2007 8:27 pm Post subject: |
| so the 8's are not the earlier 23mm offset then? (ET23). |
Posted: Fri Feb 09, 2007 2:46 am Post subject: |
the fuzion ZRi are a pretty good tire actually, a touch less grip than the Falken ZE512 but they sure do last longer. _________________ 3 928s, |
Posted: Fri Feb 09, 2007 5:05 am Post subject: |
Good choice.. a 60 16 is to tall ..in a 16 anyways imagine it would be the same in a 15.. I purchased 2 used 205 55 16 studded snow tires
here before x-mas for 150.00 from a nearby shop there cooper weather master st
Before I learned what brand of tire you put
on these cars I bought a full set of white lettered TA
radials I still have them also there 14s though.. white letters
look kind of sharp. Though black side walls is the way to go. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Fri Feb 09, 2007 7:21 am Post subject: |
| Lizard wrote: | | the fuzion ZRi are a pretty good tire actually, a touch less grip than the Falken ZE512 but they sure do last longer. |
From what I understand, the Falken is a better drag tire, and not as good as the zri in cornering.. to soft of sidewall.
ic932, the rims are all late offset. _________________ [This Space For Rent] |
Posted: Fri Feb 09, 2007 7:58 am Post subject: |
the falkens when run at proper pressure dont really have any sideways roll, and when cornering I did find the Falken to have slightly better grip than the ZRi but at the same time, you should technically be cornering that hard on the street anyways. _________________ 3 928s, |
