931 Tech To do list
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10
kondzi
PostPosted: Sat Dec 03, 2022 7:53 am    Post subject: Reply with quote
I'll try to check tomorrow where I have welded in mine. So far so good, and it's already few years, but nut that much mileage.
Konrad
'89 951 US
'81 931 RoW (TBD)
PostPosted: Sat Dec 03, 2022 8:01 am    Post subject: Reply with quote
Put it where it fits, it works even if its in the rear end of the car. I have no permanent installation, so i put it in the tail pipe with an adapter when its measurement time. Apart from idle it works perfectly. Just put it in a good angle according to the instructions, to avoid a short life span.
kondzi
PostPosted: Mon Dec 05, 2022 4:13 am    Post subject: Reply with quote
So here's how I have it on my car.
[/img]
Konrad
'89 951 US
'81 931 RoW (TBD)
PostPosted: Wed Dec 07, 2022 5:29 am    Post subject: Reply with quote
MOTANUL wrote:
The bushing on the steering column is no longer available. Maybe I can put a teflon or polyurethane bushing
IS available.
MOTANUL
PostPosted: Sat Dec 10, 2022 7:12 am    Post subject: Reply with quote
IS available.
Were?
Although I wrote a long time ago this winter, I intend to dismantle there again.
1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
sold Porsche 924 NA 1979
MOTANUL
PostPosted: Sat Dec 10, 2022 7:25 am    Post subject: Reply with quote
Thank you for the answers.
To make a long story short: there are 2 areas where it can be mounted.
1. After Turbo flange
2. before the first drum
1. After turbo flange. Do not strictly follow the assembly instructions. (turbo in front, manifold above, wastegate in the back (a lot of heat around).
2. before the first drum. Follow most assembly instructions. It can be placed on top of Exhaust pipe and on the side (with an angle of 10 degrees).
MOTANUL
PostPosted: Tue Dec 27, 2022 11:22 pm    Post subject: Reply with quote
I managed to convert the ignition to electronic ignition with the original distributor. (I had something similar on 924 2.0 NA).
Also new Ignition coil. (suitable for electronic ignition)
The car starts much better now, runs better.
The spark is better, the current consumption is much lower.
MOTANUL
PostPosted: Fri Apr 07, 2023 5:30 am    Post subject: Reply with quote
I intend to rebuild WUR. I found about 4 offers of gasket kit. Only one is complete (first).
Has anyone tried to rebuild the WUR? Are there other better gasket kits?
https://www.ebay.com/itm/385328839948
https://www.ebay.com/itm/301834352909?hash=item4646bab90d:g:oj8AAOSw7hRWO1nG&amdata=enc%3AAQAHAAABEMds4agbhPfulR%2BAZaAwpQAncqRHvDDx4opt%2BbteAQf%2BNU6WnkOXjtF%2BUN0RQFonxK702vc5SE12ZhiYmDip4PfgHyDs1PWHYJDq8y1UelCp36TDFrNuu8NqCODrMc4YaqB3SWPanZ5IqOZdfVNRPi7rA%2FpfgMLab93YuiHHwQhXJDiPFvAJ0GWLWUKAZQEDPthzBhf0K4sMX%2FgVxRk0yTjjb85RrtKPIVVYLl84ooInLYK9i2RvxhxLQiRHCZD7ucpLU8rcd9H7h2XDMS65SdRNSC%2Bzqf5%2FJvpxYSi%2FLMS%2BALytDeJui9X%2FJpjyDMR95Rm6Rwcm3uFx4iD8DGcNpyiuP4fVf4LhR1UXGNhuIPwR%7Ctkp%3ABk9SR8jfh4DrYQ
https://sierramadrecollection.com/products/warm-up-regulator-repair-kit-p31424
https://www.ebay.co.uk/itm/223317221661?mkrid=710-53481-19255-0&siteid=3&mkcid=1&campid=5338306792&toolid=10001&customid=&mkevt=1[/url]
Page 10 of 10
