FRporscheman
Joined: 02 Feb 2007 Posts: 16 Location: San Francisco
Posted: Fri Feb 02, 2007 9:07 pm Post subject: 968 owner considering a 931, with many questions |
Hi guys, this looks like a great board, so I'll be reading a lot in the days to come. I've spent a few years on Rennlist, so please forgive my web etiquette.
I bought my first Porsche (a 944) 2.5 years ago, and sold it .5 years ago. It was an early model with the 924 interior. I bought my current 968 just over 1 year ago. My dad bought his 928 about 12 years ago I think, and my mom's 944 entered the family 20 years ago. I was driven to and from elementary school in her 944, so I know 944s like the back of my hand.
Since selling the 944 and just going with the 968, I've been very happy but I've missed the old-school factor. Plus I've always wanted to have a turbo-something. And I always sort of liked the funky skinny 924, so I thought a 931 could be interesting. Then one of my friends said he's selling a 1982 931 for $700, which has decent paint, decent interior (both of which I don't care about), and a partially disassembled engine. The whole point of getting a second Porsche would be to be my toy, so I engine work just makes it more desireable for me.
Anyway the car is an 82, with 5 lugs, 4 discs, and a blown turbo. Here come my questions:
1. I've read the turbos are worthless unless you use fully synthetic oil. Couldn't I just replace the blown turbo with an aftermarket one, or a 951's turbo or something? I wouldn't want to use full synth unless I've rebuilt the engine with all new seals and gaskets.
2. I probably would want to fully rebuild the engine, instead of replacing the turbo and calling it a day. Is a 931 engine particularly hard to rebuild? While rebuilding it, I suppose I might as well dump the cash to use upgrade goodies where applicable. What kind of stuff could I do to raise performance, and where would the parts come from? I.e., are there low-compression pistons I could get to allow bigger turbos, or some special vw crank with larger stroke, etc.
I have done a lot of work on my old 944 and my 968, like clutches, headgaskets, but I've never rebuilt an engine. Thanks for all your input! _________________ '93 968
'84 944
82 MB 300td |
Posted: Fri Feb 02, 2007 9:51 pm Post subject: |
Welcome aboard! And yes, this is a MUCH better board than that other one you mentioned.
The 82 931 is the best way to go, being a series II...better throttle body, better turbo unit, and purportedly improved exhaust manifold that was not as susceptible to cracking.
That said, that is prob'ly the first thing I would check...if the exhaust manifold is cracked, you better find a good replacement (they're rare as hen's teeth), otherwise you'll have a perpetual boost leak. And no, they're not repairable, at least judging by the lack of success of folks on this board (do a search).
The turbo rebuild will cost you a minimum of $300 from a reputable shop. Again do a search on this board to find one near you. I used Michigan Turbo in Grand Rapids. They quoted me $300 over the phone, it cost me $450 for one, and they wanted $600 for the other, which I declined.
I would have no fear of putting synthetic oil in the car even if I didn't do a full rebuild. That said, if the engine is already partly dismantled, go ahead and rebuild the whole thing. Get yourself the factory service manuals and the parts catalog on CD. If you can't find a source via search, PM me.
Performance mods, the best thing to do is to rebuild the wastegate with a 1.2 bar spring, add a boost controller, an intercooler, and possibly some sort of fuel enrichment like a methanol injection kit. Again, search is your friend for more details on all of these subjects, especially in the performance enhancement forum.
On my wide body project, I've already increased stroke and bore for hopefully some add'l low end grunt, and I had custom pistons made. If you want details on this let me know, but it's spendy.
$700 seems a little high to me for a car with a blown motor. I'd try to wear 'em down a bit...
Good luck. Oh yeah, search is your friend.  _________________ erstwhile owner of just about every 924 variant ever made |
Min
Posted: Sat Feb 03, 2007 2:42 am Post subject: |
I'd find one without a blown motor to test drive before purchasing one you have to assemble. That way you know if you like how the car feels. Buying a assemble yourself car is fine and all, but its sure nice to know what the end product will feel like before sinking money into it.
Chrenan
Posted: Sat Feb 03, 2007 4:26 am Post subject: |
The bottom end on a 931 is the same as the 924 (block, crank, and I think even rods). That part of the rebuild is not high on the difficulty scale.
Bottom end disassembly
Bottom end disassembly – caps removed
Bottom end disassembly – crank and pistons removed
Bottom end disassembly – top
Block back from machine shop – top exhaust side
Block back from machine shop – top intake side
Block back from machine shop – bottom exhaust side
Block back from machine shop – bores
Bottom end assembly – crank
Bottom end assembly – oil pickup
Bottom end assembly – 9.3:1 euro spec pistons
Bottom end assembly – rear crank seal
Bottom end assembly – oil pump and front crank seal
Bottom end assembly – oil pan intake side
Bottom end assembly – oil pan exhaust side
Bottom end assembly – oil pan front
Bottom end assembly – oil pan back
Bottom end assembly – crankcase breather _________________ 1987 951 - M193 Version for Japan |
Posted: Sat Feb 03, 2007 5:08 am Post subject: |
I would recommend that you convert to EFI as you rebuild, a rebuild is a very good idea as I would be willing to bet you have broken piston rings in there as is.
with regards to the turbo it has a unique hot side, so unless you build a custom exhaust manifold you cannot run anything but a stock unit. if you go with EFI you can upgrade the compressor side and eliminate the bulky BOV off the intake side.
rebuilding the engine is just like any other, however I would recommend that you have new hoses put on all the turbo hoses as they will leak oil.
you will not be able to run Synthetic right after the rebuild. _________________ 3 928s, |
Posted: Sat Feb 03, 2007 5:25 am Post subject: |
chrenan, you show off! pix look great, man! good inspiration for my wide body project!
| Quote: | | recommend that you convert to EFI |
Sorry Lizard, but I have to vehemently disagree with you here. EFI is NOT a straight-forward, inexpensive, or simple conversion suitable for a novice. Furthermore, EFI will do little to enhance performance on its own...in conjunction with other mods, yes, it will allow optimum performance and tunability, but on the cost: benefit ration, it offers relatively small performance advantage on its own. The main advantage of EFI as I see it is ending reliance on the aging, difficult-to-source CIS parts.
Based on my research, EFI will require a minimum $1500 to do it right, prob'ly more like $2-3K. It requires a lot of custom fabrication, and if you don't have access to that kind of equipment to do it yourself, it will cost even more. Also, it introduces too many variables into the engine rebuild. I say do the easy, obvious stuff first, get the car back up and running and save EFI as a stage II performance enhancement.
| Quote: | | you will not be able to run Synthetic right after the rebuild |
Well, to be precise, you can run synthetic, but it would be a foolish thing to do. Typical engine break-in procedures apply...use crappy single weight oil during break-in. Again, a search here or on google will return a plethora of opinions and recommendations on engine break-in. As I stated earlier, I would not hesitate to run synthetic immediately if you don't do the rebuild, and I would not hesitate to use it after proper break-in, once the rings are seated. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat Feb 03, 2007 8:15 am Post subject: |
the main reason I recommend converting to EFI while doing the rebuild is because the CIS parts have all been sitting for awhile and who is to say it will run right once together, as well all the issues with the DITC box.
If you do convert to EFI now have the spot for injectors machined out and then the injector hole opened slightly to have a Bosch injector sit in this hole that way the injector will sit further in and you will not have as much fuel hitting the wall and deatomizing.
I agree it is easier to do EFI on an engine which is already running but we have other members who could give a base running MAP if he uses MS,
if he bolts everything up with the CIS and finds that the car wont start no this no that he will be chasing electrical gremlins and troubleshooting the CIS for awhile, _________________ 3 928s, |
Chrenan
Posted: Sat Feb 03, 2007 8:47 am Post subject: |
I think that is the deciding factor, how long has the CIS been sitting? If it is totally gummed up, you could spend as much time and effort trying to get the CIS going as getting the EFI up and running.
Long term, I think I will have to go to EFI eventually, I can't see the CIS working forever. One major problem with the fuel distributor and I'll have to learn lots about EFI. _________________ 1987 951 - M193 Version for Japan |
Posted: Sat Feb 03, 2007 10:09 am Post subject: |
Lizard, Chrenan, good points...good clarification. _________________ erstwhile owner of just about every 924 variant ever made |
FRporscheman
Posted: Sat Feb 03, 2007 11:55 am Post subject: |
I'd love to do the EFI conversion eventually, but I can't afford to spend on a purchase, rebuild, turbo AND EFI all at once. That will definitely put me in the poor house.
The car has been sitting for a few years, I think. The engine was running when the PO started disassembly. The current owner thinks the PO was trying to replace the turbo, then lost interest and sold it. I've met the owner and I know him on Rennlist too - he's trustworthy. It seems I could theoretically just finish the turbo work, bolt it back together and hope the CIS still works. I hate CIS so much. My brother's 85 GTI also has CIS and it drives both of us nuts.
Well if I do buy the car, it'd be good to know what kind of costs to expect. Assuming I do all the work myself, except for special stuff like machine work, how much do you reckon it would cost to rebuild the engine?
About the exhaust manifold. If it's going to crack, and if it's the only thing prohibiting a new turbo, then I would just have a new manifold made. Is there a source for aftermarket manifolds/headers? Like for racing?
When I go to see the car in person, what things should I look for? As in, what are the typical problem spots? Also, what kind of details hint to special options and packages? All I remember right now is that it had discs and 5-lug spider web wheels. _________________ '93 968
'84 944
82 MB 300td |
Posted: Sat Feb 03, 2007 12:20 pm Post subject: |
if the car has been sitting for more than 1 year I would not even bother attempting it without doing EFI, if you get it running you will have to probably spend almost as much money on the CIS as you would to convert to EFI, I am not saying you cannot get the car going on it, but it is unlikely that it would run perfectly and at the very least you would need to dismantle and clean the WUR, or replace it.
Converting to EFI doesnt cost all that much and you dont have to get all the items at once. _________________ 3 928s, |
Chrenan
Posted: Sat Feb 03, 2007 2:49 pm Post subject: |
The guys posting on this thread (Lizard, Ideola) have lots of 924 experience and can help with many questions, as can lots of other folks on the board, so no reason to be too worried going in. I can tell you, I wouldn't have done as much work and kept my 924 as long without this board.
For a rebuild, call EBS Racing and ask about a 931 rebuild kit. That is a good start, costs around $400. Then you'll need a turbo rebuild, not sure about those costs as I have a 924, not 931. Then you'll want to replace most of the coolant hoses, those aren't super expensive, but some of them aren't cheap. The pricey stuff really is the fuel related stuff, the 2 pumps, WUR, injectors, ddistributor, none of it comes cheap. I hear what you are saying though, I didn't do EFI when I rebuilt my engine because I didn't want to complicate the process too much, and cost is always a factor with a hobby car. Maybe rebuild the engine and when it is close to done try to find someone parting out a recently running 931 and buy the fuel system? Long shot, but you never know. _________________ 1987 951 - M193 Version for Japan |
931Tony
Posted: Sat Feb 03, 2007 3:04 pm Post subject: |
FRPorscheman,
I agree with some of the guys that $700 might be a little steep for one with the engine apart.
I disagree with ideola on one point though, I STRONGLY suggest you don't put synthetic in an engine without a full rebuild. The reason for this being that regular oil builds deposits over time, switching to synthetic oil will do a great job of cleaning all those deposits out but it will also cause seals to leak, oil rings to leak, etc. Really not a pretty sight, it'll turn a great running engine into one leaking, smoking SOB.
As far as the CIS/EFI debate goes I've been recording my process in getting my 931 started after 3 years of sitting in the garage. My determination is to get it running well on CIS parts, then I plan on converting to EFI. I'll start some postings soon (and maybe a How-To or two) if it'll help.
FInally, ideola, I'd love to hear more about your engine build, sounds interesting!
but either way FRporscheman, keep us posted. H |
Posted: Sat Feb 03, 2007 10:19 pm Post subject: |
| Quote: | | I disagree with ideola on one point though, I STRONGLY suggest you don't put synthetic in an engine without a full rebuild |
Hmmm...don't mean to be contentious, but I have switched to synthetic in my 80 928 Euro, my 81 924 NA, and my 80 931. I have yet to develop any sort of oil burning problem on any one of the cars. I did not do a full rebuild on any of them either. So as I said, I personally would not hesitate to switch to synthetic again. As 931Tony points out, others may have different experience, so FRPorscheman, the typical disclaimer applies: YMMV.
I still have to disagree with Lizard regarding the cost of EFI. There are LOTS of hidden costs and it will take a LONG time to figure out EFI if you haven't done it before. So I agree with FRPorscheman and Chrenan. CIS is aging, and it sucks, and you might be screwed getting into a car that's been sitting for a while. However, you never know until you try, and no matter how you look at it EFI is the LAST thing you should tackle with a motor that is already apart. Might as well rebuild it first.
| Quote: | | ideola, I'd love to hear more about your engine build, sounds interesting |
I picked up a 931 wide body some time back (http://www.924board.org/viewtopic.php?t=14911). The car was running but had terrible boost leak due to flex hoses between the charge tube and the IC. In any event, this car is currently totally in pieces. So far, I have done the following:
- acquired new Holbert style rear quarters from AIR
- pulled and dismantled the motor
- block has been bored to 87.5 and align-honed by Holbrook Racing
- custom pistons by Diamond Racing. They are essentially the same as stock 931 pistons, designed to maintain the low compression ratio of early 931s in order to accommodate the higher boost I'm planning, BUT they are ceramic coated on top, teflon coated skirts, and have the wrist/pin height adjust for the stroker crank
- stroker crank prepped by Performance Crankshaft (another local motor city specialist). This was a weld and regrind, maintaining original journal size but increasing stroke by .25"
- rebuilt turbo by Michigan Turbo
I have acquired a buttload of other stuff, like a pre-luber, turbo timer, higher rated torsion bar, higher rated front springs, roll bar and cage, etc. I also have a bunch of other plans for the car, like rebuilt wastegate with 1.2 bar spring, boost controller, methanol injection, top-mount intercooler, etc.
Next step is to do the head...I'm planning on a fully lightened valve train and I am about 90% certain I want to go with the Carrera cam profile (all to be done by Eurorace). I am contemplating lightened rods, possibly Pauter, or I may just go with shot-peening, still undecided. Also seriously contemplating a dry sump system. And if I can find a solution, I'd like to go with a lightened flywheel.
My hope is to aggressively begin putting stuff together this spring. The project got interrupted by 2006 (one of my cars got stolen and I went thru a divorce...totally unrelated to the car hobby, I swear ). I don't know that I'll get it done this year, but I plan to blueprint the engine and document the whole process. Once it starts, I'll take photos and start a thread here to document the build and the related costs (I've kept all my receipts). PM me if you want any other details in the meantime. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sun Feb 04, 2007 12:05 am Post subject: |
I've had the same experience regarding synthetic (specifically Mobil 1) as ideola. I started using Mobil 1 in it when I got the car in fall of '92 and have had no oil leak problems. -And I have no idea if/when the engine's ever been rebuilt - as far as I know, it never was. In fact this is the tightest engine I've ever had in terms of both leakage and consumption by oil burning..every other car I've owned has leaked and burned at least some oil and all of them were run with non-synthetic. I suspect that some of the fear of synthetic-caused-oil-leakage may only be legend passed down from the early days of synthetics and they've been reformulated long since to reduce, if not eliminate the problem.
Based on my own experience (no oil leaks and 10+ years on my current turbo) I would switch right to a full synthetic if only replacing the turbo and to full synthetic right after a dino break-in if rebuilding the engine. _________________ "..it's made in Germany. You know the Germans always make good stuff."
