rummyrenz2
Posted: Mon Sep 06, 2004 8:13 pm Post subject: 924 intake manifold for carbs |
hi,i,ve been looking for a intake manifold to fit my two dcoe45 weber carbs but had no luck,does anyone know where i can find this item on its own with out the carbs included as a kit.many thanks matt _________________ M.P.RENDLE |
My924gtc
Posted: Mon Sep 06, 2004 10:00 pm Post subject: |
Try http://www.piercemanifolds.com/products.htm I think they sell them as individual components. _________________ MJ
'81 924 2.0L T
'82 924 2.3L SC/EFI <---online fall '06
Sponsor of the 944 Cup and Super Cup
Sponsor of the "2006 Battle in the Badlands" |
Vince Ponz
Posted: Tue Sep 07, 2004 6:29 am Post subject: |
Paeco.com has them but I don't know if sold seperately. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
emoore924
Posted: Wed Sep 08, 2004 1:12 am Post subject: |
| I have one sitting on my workbench right now. It is, however, attached to a head and a set of 45 DCOE's... |
Joined: 04 Dec 2002 Posts: 767 Location: Blyth, Northumberland, UK
Posted: Wed Sep 08, 2004 6:16 pm Post subject: |
Out of interest, does the intake from the VW LT 2.0 van/truck fit? AFAIK this is the engine used as the basis for ours and the LT used carbs... _________________ Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead. |
marky522
Joined: 02 Nov 2002 Posts: 335 Location: Port Huron, MI
Posted: Thu Sep 09, 2004 2:20 pm Post subject: |
i dont think so becuase i believe i read somewhere that the head on the 924 is actually a porsche design, but everything else is VW.
Mark |
Viking
Joined: 30 Jan 2003 Posts: 107 Location: Oslo, Norway
Posted: Mon Sep 13, 2004 9:38 pm Post subject: |
The head is very similar to the one used on the 2 litre Audi's. The only visible difference is that they have drilled holes for the injectors, as the Audi did not use them. (The Audi head has provisionings for them.)
The difference between "our engine" and the Audi variant is that the head takes injectors, the pistons give higher compression, and the pan is different. The block is identical as far as I could see.
(This is what I observed from an Audi "donor" engine from a car that had 50k kms on it... And turned out to be more worn then mine, so I ended up doing a rebuild of the original engine instead.) |
