anyone out there into homebuilt or experimental aviation.
coconutcowboy
PostPosted: Fri Jul 30, 2004 11:15 am    Post subject: anyone out there into homebuilt or experimental aviation. Reply with quote
Dear members.
I have another thriving group that is in the process of building home
built aircraft for up to 2 people.
If you guy's can build Porsches you can build an airplane.
I am a disabled veteran and I am.
I set up this group for like minded people such as myself.
http://groups.yahoo.com/group/sportplane
they use everything from 2 strokes to vw to subaru to honda to
motocycle engines to model A and lastly the corvair flat 6 engine.
The planes are built of either the following materials :
wood, aluminum, 4130 tubing, composite and dope and fabric.
The flight instruments an avionics should be a breeze for you guys to
scrounge up and install.
all you need is a valid drivers license and 20 hours instruction to get the new light sportplane license.
the airplanes that qualify have to be fixed gear, no more than 2 seater, not flown at night , weigh in fully loaded with people at less than 1250 lbs and stall speed of less than 45mph.
If you have plans I have 10 plans and engine and conversion manuals for $100 usd on cdrom
Sean Peyton Ross A&P / FCC GROL
Listmaster Homebuilt Tube Radio's
President and founder SPPA
84 944 2.5l NA for sale.
80 924 w/ turbo nose/ m471 option/ ac and Pasha Interior. w/ bursch header and exhaust, stage 2 cam, Audi wur and tb
ricer's shall kneel before the mighty Porsche or unforgivable harm shall befall their engine blocks.
