Matias Guest
Posted: Sat Dec 08, 2001 5:46 am Post subject: |
Hi, guy´s. My completely standar 931 is receiving a head job right now. I think is time to take some extra HP of these engine.
My first idea is to raise the boost to 1 bar. My secon idea is to take of all the emision control thing´s that steal power from my engine. Here in Argentina we don´t have emmision´s laws.
So , here is the question.... what kind of thing´s do you recommend me to take out, may be the charcoal can? the oil recirculator?
thank´s for all.
Smoothie Guest
Posted: Sat Dec 22, 2001 8:45 am Post subject: |
Hey, be good to your lungs, "they're only human". I don't think the charcoal can or oil separator put any drag on performance anyway, so; I'd leave them alone. Boosting the boost is an effective performance improver - just have to be carefull not to overdo it. Too much boost will cause detonation. Water injection, intercooling and fuel enrichment are ways to prevent that. I turned up my boost some and use water injection (blue windshield washer fluid water injection).
larso Guest
Posted: Sun Dec 30, 2001 7:38 am Post subject: |
| The seperator throws oil and oil vapor into your engine, I don't see how that can decrease performance? Of course it does! The only good thing that it does is releive pressure, so you don't want to plug it up, otherwise you will have oil spraying out the oil cap on your cam cover. |
Matias Guest
Posted: Mon Dec 31, 2001 8:25 am Post subject: |
But wouldn´t be better to have there one of those little "air filters" used for the V8´s, so the pressure could be released, without having oil getting trough the air-box?
Just asking.
Posted: Mon Dec 31, 2001 10:08 am Post subject: |
those "little air filters" are actually part of an aftermarket oil catch can.
Basically a catch can traps the oil in the vapour and vents the filtered air to the atmosphere instead of pumping it back into the inlet as required by clean-air laws.
A simple catch requires you to regularly empty the trapped oil, smarter ones drain the oil back into engine.
They're quite cheap to buy and quite easy to make. Have a look in the tech articles on the AutoSpeed site, they ran a how-to a while back. |
Smoothie Guest
Posted: Thu Jan 03, 2002 3:21 am Post subject: |
| Thanks for the edu there Larso. I must have had a mini stroke or something. Of course the oil seperator puts oil back into the crankcase (no problem there); but, heated oil vapors to the intake to be burned. There would be some performance issue there. I just think it's negligible compared with the performance increase that you get by upping the boost and would still leave the emissions stuff alone. |
Matias Guest
Posted: Thu Jan 03, 2002 7:49 am Post subject: |
I know the performance gain wouldn´t be minimum, but If I could replace all the hoses with one little breather like the one´s used in the valve cover of the V8´s, the pressure would still be released and I would have less hoses, and the engine compartment would look cleaner. I really don´t like that plastic box (purolator) beside my engine.
Is more a look´s thing than performance.
