Kpa/ cm2 bar and PSI
geddes66
PostPosted: Mon Nov 03, 2003 4:02 pm    Post subject: Kpa/ cm2 bar and PSI Reply with quote
Ok< I saw the post that 1 bar is 14.503 PSI. is a kpa/cm2 another name for a bar or is it totally different? If so what is it in PSI? I am guessing it is about 10 PSI. this is for oil pressure guages and peace of mind.
The Porsche is now my son's, my car is cooler, slower but cooler.
PostPosted: Tue Nov 04, 2003 1:00 am    Post subject: Reply with quote
Don't know about a kpa/cm2, but an at(kp/cm2) = 0.981 x bar (according to the online converter in my next post) or an at(kp/cm2) x 0.981 = bar (according to the way the tech specs booklet states it).
"at(kp/cm2)" is called a "technical atmosphere".
"kpa" is a kilopascal. Don't know what just "kp" means, maybe the same thing.
Where did you see "kpa/cm2"?
924 turbo
PostPosted: Tue Nov 04, 2003 1:03 am    Post subject: Reply with quote
http://members.rennlist.com/pirtle/s4specs.htm
http://www.matheson-trigas.com/mathportal/_pdfs/products/Conversion%20Tables.pdf
According to this information, 1 kp/cm2 would be equal to approximately 14.78 psi.
kp is kilopond, kPa is kilopascals. Some of the oil pressure gauges are marked in kiloponds per square centimeter.
Jon Furst
PostPosted: Tue Nov 04, 2003 1:27 am    Post subject: Reply with quote
More junk on that:
1 technical atmosphere (kp/cm2) is 14.223psi. (according to the online converter below)
A "kp" is a "kilopond", "kpa" is still a "kilopascal".
Online converter - http://www.geoforum.com/knowledge/unit/pressure.asp
PostPosted: Tue Nov 04, 2003 2:11 am    Post subject: Reply with quote
Hey, screw the online converter. I played with it some more - apparently it's buggy and it also rounds the values you enter. I'm inclined to think the Porsche tech specs booklet and the other stuff from 924Turbo is correct as in kp/cm2 x 0.981 = bar, so 1 kp/cm2 = 14.78 psi.
Obviously, that still doesn't answer the question, "What is kpa/cm2 equal to?".
Later...
Here's something that suggests 2.3 kpa/cm2 equals 35psi (see the first search result): <click> Yahoo search on kpa/cm2 That would make 1 kpa/cm2 approximately equal to 15.22psi, so both kpa/cm2 and kp/cm2 are probably close enough to a bar for the purpose of reading an oil pressure gauge.
Ordrune
PostPosted: Tue Nov 04, 2003 1:06 pm    Post subject: Reply with quote
My conversion tables here are saying that.....
1 bar =100 kpa
1 kpa =0.145 psi
1 psi = 6.89 kpa
As far as I know(I could be totally wrong) Kpa is always calculated to Cm2 (kpa/cm2) unless otherwise stated.
'79 924 supercharged,intercooled
Neil924
PostPosted: Tue Nov 04, 2003 1:19 pm    Post subject: Reply with quote
1 bar =100 kpa
1 kpa =0.145 psi
1 psi = 6.89 kpa
Correct. I didn't psi to kpa but the other two are correct.
geddes66
PostPosted: Wed Nov 05, 2003 4:12 pm    Post subject: Reply with quote
OOPS! my bad. I meant kp/cm2 not kpa. So my small gear head will go with about 15 for every 1 on the guage. So 4 is about 59 psi. A safe oil press at 3000 rpm. (figuring all those decimal points is a good way to miss a curve.)
Thanks all.
