lmz
Joined: 31 Aug 2003 Posts: 34 Location: Sthlm, Sweden
Posted: Sun Oct 12, 2003 3:48 am Post subject: Help, leakage! |
Iīve just discovered that the floormat under the driver seat and the left rear seat are really moist, I just canīt figure out where the water is coming from....has anyone had the same problem? _________________ 924 -78, restoration in progress.... |
Posted: Sun Oct 12, 2003 4:36 am Post subject: |
Sirens ,bells and whistles youve just won the
one million dollar why is the passenger floor side
wet and the back also pass. side also. Well its a
darn good question.with a fine darn answer your leaken
from somewhere like the firewall frame points or a hole
somewhere...most likely up high on the firewall and ontop
also like the battery area.  _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
lmz
Posted: Sun Oct 12, 2003 4:48 am Post subject: ... |
Hmm....ok....right... the firewall you say...could you put it in "stupid european layman" terms perhaps? Or a big nice pic
Poured some water on the roof and hatch, couldnīt spot any direct leakage though.
Thx dude.
ps. Was your reply a pun by any chance?  _________________ 924 -78, restoration in progress.... |
Posted: Sun Oct 12, 2003 5:33 am Post subject: |
"Firewall" is just the sheet metal that seperates the engine from the passenger compartment.
It's common to have rust damaged metal near the battery mainly from battery acid leakage, but also just from the seams aging and needing new seam sealer. When the seams and/or metal degrade, there's a path for water to drain onto the floor.
You can also have a seam open up from rust or a drainage tube come loose at the sunroof. there are 4 drainage tubes - one at each corner. A problem here can cause a leak that invisibly trickles down behind the headliner and trim then under the carpet.
Try a search. This one's been discussed many times before.  _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Sun Oct 12, 2003 5:46 am Post subject: |
No no pun ,there is a bunch of topics on where they leak though.
mine was really leaky and I fixed it. Hey you live in the country
that Peter Forberg is from. _________________ 1979 porsche 924 Na
lmz
Posted: Sun Oct 12, 2003 9:17 am Post subject: |
Yep, true, polar bear land
The part where itīs most wet is just in front of the rear left seat, probably a leak from back there somewhere. Also the tube in the compartment over (behind) the left rear wheel seems to be cut or something, is it supposed to just end at the bottom of this compartment? _________________ 924 -78, restoration in progress.... |
lmz
Posted: Sun Oct 12, 2003 9:19 am Post subject: |
..oh, and no sunroof on mine though. _________________ 924 -78, restoration in progress.... |
Roger
Joined: 06 Jan 2003 Posts: 1235 Location: Cordova, TN
Posted: Sun Oct 12, 2003 10:59 am Post subject: |
Its strange that is is wet on both sides. I would guess it has to be the rear hatch seal since you dont have a sun roof. I might also want to jack the car up and look for damage underneath. _________________ 1981 924 NA
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs. |
Posted: Sun Oct 12, 2003 11:23 am Post subject: |
Well it could be from the master cyl side there
I had a crack there on the seam there where the fender well and firewall meet the cracked ended up exstending all the way into the master cyl,
mounts. _________________ 1979 porsche 924 Na
lmz
Posted: Mon Oct 13, 2003 5:18 am Post subject: |
Iīll do some checking of that tomorrow, also Iīve taped the rear hatch īcause we had rain last night and Iīll see if it still gets wet under there. _________________ 924 -78, restoration in progress.... |
924 turbo
Joined: 02 Nov 2002 Posts: 1566 Location: Simi Valley, CA, USA
Posted: Mon Oct 13, 2003 10:32 am Post subject: |
Just to clear up, the carpet is moist only on the driver's side, or the passenger side as well? You said driver's seat and left rear seat, so you only mean the driver's side, right?
You may want to check the two round rubber drains for the underhood compartment between the engine bay and the windshield (where the battery, interior fan, and windshield wiper motor are). They easily get clogged and if water pools there it may work its way through a crack and soak the interior carpet. If you are able to find the crack or hole, you should be able to seal it up, but make sure you keep those drains clear or you may have this problem again in the future.
Good luck! _________________ Jon Furst |
lmz
Posted: Mon Oct 13, 2003 4:34 pm Post subject: |
Yep, itīs just the left side thatīs wet, mainly back at the rear seat, less so towards the pedals, so it has to come somewhere from there.
Couldnīt believe my eyes today, during the night, some #### had broken in, stole my new fuel pump(which was not yet installed), front Porsche emblem and almost tore my new Momo wheel out....plus carving a bad word in swedish on the hood and a line on the right side with a key. That wheel alone has made me live on bread and water this month, now I need a new pump and probably a paint job as well!
If I ever find the person Iīll make him bleed in so many ways. _________________ 924 -78, restoration in progress.... |
lmz
Roger
Posted: Tue Oct 14, 2003 10:26 am Post subject: |
Sorry to hear about the vandalisium, that just sucks. I firmly belive that someday everybody gets what they deserve. I know thats not much consolation right now though.
The steering wheel is not ricey at all. I like it, and I would love to be able to have some leg room under the steering wheel. _________________ 1981 924 NA
lmz
Posted: Tue Oct 14, 2003 7:54 pm Post subject: |
Thx dude, fortunately I was able to rub the scratches out, took me about four hours in total though. Such a waste. Well, at least it shines a bit better now. _________________ 924 -78, restoration in progress.... |
