Joined: 29 Jul 2001 Posts: 9063 Location: Royal Oak, MI, USA
Posted: Tue Sep 23, 2003 9:21 am Post subject: |
Man, I was willing to bet on a bad ground... Well, replace it anyway... the engine to firewall ground. _________________ Vaughan Scott
78 924 N/a
Joined: 20 Mar 2003 Posts: 769 Location: Pacific N.W.
Posted: Tue Sep 23, 2003 4:27 pm Post subject: |
I don't believe in "snake oil mechanic-in-a-can".  _________________ 1978 924 n/a |
Mikri184
Joined: 12 Sep 2003 Posts: 746 Location: Ferndale, WA
Posted: Tue Sep 23, 2003 5:14 pm Post subject: A cleaner, not snake oil |
| I don't use snake oil either. But needed to clean this car out after sitting eight years. Things weren't flowing properly/ The seafoam. Is a cleaner thats all says so on the can. That's why it was suggested. I was concerned about the valves, after have bad injectors seals and out side of tearing the head down. Which wasn't an option. I needed something that could do the cleaning with out further gumming up the system, Seems to have worked. And I would recomend it. Anyways few more adjustments car is still running great up to a 100 mph on the freeway no problems. By the way I did make sure the ground strap was in good order and clean. Thanks |
Posted: Tue Sep 23, 2003 10:33 pm Post subject: |
Um, no, um, you weren't listening to me.
REPLACE IT!!!
I don't care if you polish it with a friggen dremel; it's still not as good as a new ground strap. _________________ Vaughan Scott
Mikri184
Posted: Wed Sep 24, 2003 4:04 am Post subject: hmmm |
| Your right there on not as being as good as new. Try to get one this afternoon. Did replace the battery wires though with new positive and negative. Thanks |
