John
Posted: Sun Aug 31, 2003 7:34 am Post subject: Cant start car for 10mins when hot |
Hi all,
I can not start my car for 10 mins when it is hot, any ideas?
1983 N/A 1924 UK _________________ Many Thanks
Ross
1983 UK Porsche 924 |
TonD
Joined: 26 Jul 2003 Posts: 72 Location: Rotterdam, Holland
Posted: Sun Aug 31, 2003 7:47 am Post subject: |
When reading topic title, there's three words comming up:
WUR (Warm Up Regulator), also cold start valve, try using Search on those topics...must be great help  _________________ Just remember I aint American nor English, so please don't blame my language  |
kaffine
Posted: Sun Aug 31, 2003 10:23 am Post subject: |
Does it crank? _________________ 80 924
80 931
The best desciption of an atom boils down to something unknown is doing we don't know what.
Sir Arthur Eddington |
dwak
Joined: 03 Nov 2002 Posts: 839 Location: Eastern Ontario
Posted: Sun Aug 31, 2003 12:08 pm Post subject: |
Sounds like you need to rig a manual cold start valve button. This is outlined somewhere on this board. Common problem. Simple jury-rig solution.
dwak |
Roger
Joined: 06 Jan 2003 Posts: 1235 Location: Cordova, TN
Posted: Sun Aug 31, 2003 12:16 pm Post subject: |
I am not 100% certian about euro cars. However the WUR and the cold start valve have little to do with hot starts on my 81 US spec car. The check valve (yours may be in the fuel pump) and the fuel accumulator are more likely the problem. _________________ 1981 924 NA
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs. |
Posted: Sun Aug 31, 2003 1:20 pm Post subject: |
Usually this is caused by vapor lock when the fuel boils in the fuel injection lines. The cure is to run the fuel pumps long enough to get some liquid fuel back into the lines.
I just turn the key to the run position, listen for the pumps to run and stop,then turn the key off.
Repeat about 5 times, then try to start it. |
dwak
Posted: Sun Aug 31, 2003 9:55 pm Post subject: Re: Cant start car for 10mins when hot |
| John wrote: | Hi all,
1983 N/A 1924 UK |
Come on, I'll bet money on this one. This is a classic 924 quirk. I've had it on 3 of them. The real problem is usually elusive and can be expensive to track down and fix but for one reason or another the car needs that little extra shot of fuel from the cold start valve but won't get it if the engine is warm so you do it manually. I'll see if I can find the article that describes this.
dwak
Or this: Why won't my car start when it's warmed up, even though it starts fine when it's cold?
This is a common problem on 924's. The first thing to do is make sure that the car is running and tuned properly. Go through the tune-up section above, to make sure all the basics are covered. Secondly, make sure that it's only a hot-start problem, not when the car is cold. Cold-start problems are different, with different solutions (cold-start FAQ section).
If none of these fix the problem, chances are you do have the "hot-start' problem. This is caused by fuel pressure not being retained at a high-enough pressure after engine shutdown. It is characterized by an engine that will restart within, but not after, about 15 minutes of engine shutdown. To fix this problem, go to the Technical Section under Fuel System. |
Vince Ponz
Posted: Sun Aug 31, 2003 11:13 pm Post subject: |
Check fuel pressure.
My guess is the check valve. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Posted: Mon Sep 01, 2003 12:14 am Post subject: |
Agreed, the lack of sustained pressure, causes the fuel to boil at a lower temp.
But in any case, running the fuel pumps is an easy work around. |
Posted: Mon Sep 01, 2003 2:57 am Post subject: |
ok here are a couple of other things to check, pull the injectors and see if they are leaking, if they are it could cause it not to want to start when hot as it will drain the pressure out of the system and sometimes almost flood the engine, also checkthe fuel accumulators in the back just infront of the fuel tank, if they are leaking at the bottom again they will drain the pressure in the system causing abit of a start issue, now both of these might cause a tiny bit of a cold start issue as well but alot of people dont notice the cold start issues as they think the car is cold and are used to carburated cars that are normally difficult to start in the morn. _________________ 3 928s, |
Rafael
Posted: Mon Sep 01, 2003 6:46 am Post subject: |
This is a post that i put some time ago.
Try with this before change nothing.
Iīve resolved the problem.
First of all, the botton like you have, only works when the engine is cracking after you left the key of the contac in normal position, the power to the cold start valve itīs of, and the engine need more fuel to run.
Try this, take the contats of the cold start valve apart disconect the wires and cut it (THIS IS VERY IMPORTAT because the wires that come from the car are given + or - to the valve) take + from the battery directed and the ground with the botton, so you have all the control to activated the cold start valve, and left it the time that you want and the time that the engine need to run well.
When the engine cold you must push the botton to start because know you have the control of the valve, and in warm starts you push the botton and when the engine start left it some time until you feel the engine is run ok.
If it works to you you can put it a fuse, and some reles like i did for the cold starts.
Try this and tell us. |
Roger
Posted: Mon Sep 01, 2003 8:41 am Post subject: Re: Cant start car for 10mins when hot |
| dwak wrote: | | John wrote: | Hi all,
1983 N/A 1924 UK |
dwak
Agreed forcing more fuel into the intake via the cold start valve will allow the engine to start more efficently. IIRC this is a fix for the 1980 and earlier models. By 1981 Porsche made modifications to hot start system. I am not sure about the European 1983 model though. If the hot start system is working properly I am guessing that jumping the cold start valve would not be necessary on the 1981 or later models. _________________ 1981 924 NA
