MSD ignition feasability
PostPosted: Tue Jul 10, 2001 10:02 pm    Post subject: Reply with quote
Email: JvGelderen@aol.com
Date: 10 Jul 2001
Time: 22:02:13
I have a 1977 NA 924. I have the standard CD ignition that it came with. What benifits would the MSD unit provide? Will the unit hook up to the internal portions of the distributer, or would a competitors product work better.
Thank you
PostPosted: Wed Jul 11, 2001 12:17 am    Post subject: Reply with quote
Email: polaris7@softhome.net
Date: 11 Jul 2001
Time: 00:17:17
I got an MSD 6a in mine. I don't know how much better it is with the MSD, because my engine wasn't running before I put on the MSD and a dual Weber setup. Car is still not drivable yet though.....but soon.
The MSD definetly does what it says, when testing the spark and just cranking over, the spark goes like an arc welder!
You do need the tac adaptor so your tac can still function with the MSD though.
Hope that helps,
Alex R
Eugene Or
white '79 N/A
PostPosted: Wed Jul 11, 2001 12:42 am    Post subject: Reply with quote
Date: 11 Jul 2001
Time: 00:42:43
Hope that helps,
Alex R
Eugene Or
white '79 N/A
PostPosted: Wed Jul 11, 2001 2:54 am    Post subject: Reply with quote
Email: jod3511@home.com
Date: 11 Jul 2001
Time: 02:54:19
Alex Im up in Salem and have plans to use the MSD6A also thats really neat that you to Id love to see a pic or 2 of your car I have a 79 also let me ask where did you mount the msd im putting mine either where the battery used to be or where it is now ,where the rear seat used to be...and you had to use the tach thing ie huh
PostPosted: Wed Jul 11, 2001 10:48 am    Post subject: Reply with quote
Email: ponzv@aol.com
Date: 11 Jul 2001
Time: 10:48:39
I have had a Msd unit in my car for a long time being I have 2 45 DCOEs in the car. Works fine.Pictures are on this site under the 1977 year under my name.
PostPosted: Wed Jul 11, 2001 8:55 pm    Post subject: Reply with quote
Email: Polaris7@softhome.net
Date: 11 Jul 2001
Time: 20:55:57
Hey Joe,
The MSD unit is behind the drivers headlight where the original CD unit usually is. If you are going to put one in, I would recomend placing it in the battery tray as there is about 45,000 volts traveling on the spark lead, and you want it as close to the distributer as possible so you don't get interfearance in your signal wires. I didn't get any pictures of the MSD taken, but here are some pictures of my car. It is up on jack stands (still in the middle of changing the clutch etc), so the front wheels are hanging down.
http://home.att.net/~alexroy/924onstands.jpg
http://home.att.net/~alexroy/924sidemarker.jpg
http://home.att.net/~alexroy/924backmarker.jpg
Alex R Eugene Or '79 N/A, Webers, MSDs, etc.
