Engine vibration damper system
ted von Kampen
PostPosted: Sun Oct 20, 2019 5:36 am    Post subject: Engine vibration damper system Reply with quote
I have a 1981 Porsche 924. While I have a few rattles, etc to figure out, I noticed on the parts listing that there is a vibration damper system shown. It has a bracket that goes to the engine and a small shock absorber type system that attaches to the frame or somewhere.
My question
Did all years use that system and if so where is it located on a 1981 NA 2 liter?
Thanks,
Ted
porsche_reg
PostPosted: Thu Oct 24, 2019 1:10 am    Post subject: Reply with quote
ted - I don't know a direct answer for you, however I can tell you my '79 na had it. I had stiffer mounts installed and didn't reinstall the vibration system. I don't recall exactly why not, but I know the bushings weren't easy to find or generally available, so that played a part. It's not my daily driver, so I don't mind the rough feel w/o it and the stiffer mounts.
Have you checked the link below to locate the location of the mount?
http://www.autoatlanta.com/porsche-parts/924.php
Prev: '81 BMW 320i
'05 997.1 C2
Current: '79 924 n/a (family owned since new)
'12 Subaru Outback
ted von Kampen
PostPosted: Thu Oct 24, 2019 2:07 am    Post subject: engine vibration damper Reply with quote
Thanks for the reply. I looked at that picture on the link. That is what I had to look at before. My problem is I cannot find it. Where exactly is it mounted?
Car is put away right now but I need to take it out again so can look more.
Thanks,
TEd
porsche_reg
PostPosted: Thu Oct 24, 2019 10:29 pm    Post subject: Reply with quote
oh, I see. The diagram is somewhat limited on where exactly it's mounted. My car is in a condo parking garage, don't go down there much... but next time I do I'll see if I can get a pic of where mine would have been mounted. I think I can visually observe it. Should have some time this weekend to get this done.
Prev: '81 BMW 320i
'05 997.1 C2
'12 Subaru Outback
davidschmalz
PostPosted: Fri Oct 25, 2019 12:35 am    Post subject: Reply with quote
The vibration damper is located somewhat between the oil filter and alternator apparently only on 2.0L NA cars. Check out this photo and description from 924.org:
"The vibration damper below (13 through 17) is only on 924 and not the 931. So there is a very good possibility that you can get by without! Specially if you can't get it for less than the roughly $250 list!!!"
My car has one, but it is missing some bushings and appears to be useless. I did install the Vibra Technics Street motor mounts a year ago and am quite happy with the results. The car is still a shaky, rattling beast, but at least it no longer feels like the engine is going to oscillate right out of the chassis!
1979 Porsche 924 NA Petrol Blue
1982 Vanagon GL Air Cooled Monaco Blue over Kurilian Blue
porsche_reg
PostPosted: Sun Oct 27, 2019 7:30 am    Post subject: Reply with quote
yeah, there it is, nice job. I also went with the Vibra-Technics street mounts and am happy with results. Again, did not add the vibration damper back in.
Prev: '81 BMW 320i
'05 997.1 C2
'12 Subaru Outback
gerben1986
PostPosted: Tue Oct 29, 2019 7:44 am    Post subject: Reply with quote
I have never seen this damper on a 924. So I think it wasn't on the 1980+ models.
911SC - 1980
stan_5150
PostPosted: Tue Sep 12, 2023 11:00 pm    Post subject: Reply with quote
Trying to get my crossmember off....how do you access the dampner for removal? Thanks in advance.
1978 924 N/A
Mclaren924
PostPosted: Wed Sep 13, 2023 3:28 pm    Post subject: Reply with quote
it's a little bolt on the bottom of cross member inside that concave portion, that or unbolt the bracket from behind the alternator. If I remember, its a pain to get that lower nut off if it's seized on as it will just spin with the shaft on other side. Getting behind to that bracket is a EEFing B word to get at though.
stan_5150
PostPosted: Fri Sep 15, 2023 5:03 am    Post subject: Reply with quote
Yes - that's the issue that I'm trying to work thru. Looks like its behind the oil filter which I need to remove anyway so wondering it that provides better access. Any other help is welcome. Thanks!
1978 924 N/A
Mclaren924
PostPosted: Fri Sep 15, 2023 8:27 am    Post subject: Reply with quote
yup, pull the oil filter. If still hard to get at pull the alternator too. Good luck
