rcarson25
Posted: Thu Dec 15, 2022 1:28 pm Post subject: Headlight issue |
I have 1981 924 Turbo mostly running but have issues with my headlights currently. Motors work fine, ground is happy at the headlights, but I am not getting power. Changed the headlight relay and still nothing. Does anyone have a pin out of the headlight switch and relay. I checked the terminals at the fuse block and currently the relay is not getting ground at the S terminal which I assume I would get from the switch. I do have 12v at the 30 terminal, I also checked the relay and it seems to be working when it has power and ground. Any help would be much appreciated. |
