Porsche maintenance kit
andrewsutton14
PostPosted: Sat Dec 17, 2022 10:57 am    Post subject: Porsche maintenance kit Reply with quote
I just acquired a 1987 924S and ordered the Porsche Maintenance Kit #944 100 930 00. It comes with an air filter, oil filter, fuel filter, spark plugs, and a seal. The seal is aluminum (like a gasket) 26.5mm OD and 22.25mm ID. Where is this seal used?
madislandguy
PostPosted: Sat Dec 17, 2022 5:29 pm    Post subject: Reply with quote
Oilpan drain plug gasket?
andrewsutton14
PostPosted: Sun Dec 18, 2022 2:55 pm    Post subject: Reply with quote
I haven't done an oil change on it yet, but I'll bet you are correct! Thank you!
PostPosted: Tue Dec 20, 2022 3:41 pm    Post subject: Reply with quote
Cap, rotor, wires?
andrewsutton14
PostPosted: Tue Dec 20, 2022 10:12 pm    Post subject: Reply with quote
Cap, rotor, wires?
Well, that's what Porsche considers a maintenance kit. I intend to replace the distributor, cap, rotor, and wires- along with a timing belt kit replacement. Looking like next spring to tackle those.
