Headlight Motor Issue 77 Martini Edition
TommyPorsche
PostPosted: Thu Sep 29, 2022 6:14 am    Post subject: Headlight Motor Issue 77 Martini Edition Reply with quote
Greetings!
I've recently purchased a 77 Martini Rossi Edition 924. I'm exited to own the car and look forward to tinkering with it.
One of it's issues is the headlights not retracting back down. Popping up is no problem. Thus, the dash lights, etc. stay on as well until I lift the hood and manually retract the headlights by turning the knob on motor counter-clock wise. I did try a new motor relay, but the issue still exists. Any input is appreciated.
Thank in advance!
Tommy
Eliza
PostPosted: Thu Sep 29, 2022 9:10 pm    Post subject: Reply with quote
Hi Tommy,
what you describe, is this with the enginne running or just ignition-on?
With the pop-ups open and on, and your dash lights on - what happens if you switch off the ignition?
All lights off but pop-ups still open?
Does the setting of your light switch change anything at all? It's a two-stage switch btw.
Eliza
1985 924 NA RoW
1981 931 S2 RoW
65sprint
PostPosted: Fri Sep 30, 2022 11:27 am    Post subject: Reply with quote
I have a Championship Edition too, they're fun cars.
TommyPorsche
PostPosted: Fri Sep 30, 2022 4:03 pm    Post subject: Headlight Motor Issue Reply with quote
Hi Eliza,
I appreciate the response. Let me describe what transpires more thoroughly.
With key out of ignition (not running):
First Headlight Switch Position -
- Headlights pop up, but don't illuminate
- Parking, rear, side marker, license and dash lights are ON
Second Headlight Switch Position: Same as first position
Key in ignition and car running:
- Parking, rear, side marker, license, and dash lights are ON
Second Headlight Switch Position: Same as first position, but headlights do illuminate
BACK to First Switch Position: Headlights stop illuminating, but still up. All other lights are still on.
Back to "Off": Headlights remain up and only the dash and rear license plate lights remain on. They stay on until I manually retract the headlights
I hope that helps.
Thanks!
And Yes, "65sprint." So far, it is a fun car and I really like the looks of this model with it's appealing color scheme.
Eliza
PostPosted: Sat Oct 01, 2022 4:33 pm    Post subject: Reply with quote
Hi Tommy,
That's not how the popups SHOULD behave ( or the light switch ).
A brilliant troubleshoother for the whole enchilada can be found here:
http://944foot2thefloor.blogspot.com/p/tutorials.html
Go to Body/Interior and follow
6. Headlight electronics overhaul
and
7. Headlight mechanism overhaul.
That should get you sorted!
1985 924 NA RoW
1981 931 S2 RoW
TommyPorsche
PostPosted: Mon Oct 03, 2022 5:58 am    Post subject: 77 Martini Headlight Issue Reply with quote
Eliza,
Thanks so much for your help and that link. I'm going to start by getting out an old toothbrush and some Q-Tips and degrease and re-grease the moving parts and look for any obstruction. Hopefully, I won't have to delve further. Though, I do enjoy figuring things out to a happy remedy.
Thanks again!
Tommy
Eliza
PostPosted: Mon Oct 03, 2022 2:07 pm    Post subject: Reply with quote
If you get stuck and need help, just ask!
Good luck!
Eliza
1985 924 NA RoW
1981 931 S2 RoW
