james911996
Posted: Wed May 11, 2022 7:38 pm Post subject: Engine cooling issues |
Hi All,
Had the new to me 924 2.0NA race car out for the first time this week at Donington Park for a track day.
Brakes and handling performed well. Only issue we had was engine cooling.
After about 5 laps from cold a cooling lap was needed as temperature was getting into the red. Then a cooling lap between every 2 laps or so.
(car also needs a lot of cranking to start up)
A local 924 racer at the track also thought the engine sound was missing some ‘bite’. He thought timing could be causing the overheating issue and the engine sound.
I've been advised to look at some ducting around the radiator.
Any thoughts on what could be causing this and what the best off the shelf cooling upgrades are ?
thanks for any help!
Joined: 29 Jul 2001 Posts: 9082 Location: Royal Oak, MI, USA
Posted: Wed May 11, 2022 9:40 pm Post subject: |
For sure too much advance can cause overheating... without any details on the engine build, can't say if you need more substantial cooling mods.
It is a good idea to ensure the gaps around the edge of the radiator, against its surround, are filled - foam strips can work well here.
Also, you should definitely be running an oil cooler - not clear if you have any. _________________ Vaughan Scott
Posted: Wed May 11, 2022 11:07 pm Post subject: |
A standard 924 should easily be able to do a 12h endurance race, otherwise something is wrong. Timing could be of but the rad could of course be in rough shape, or a sticking thermostat. Upgrades and oil cooler helps, but it could be good to find the source of the problem first. And plan an oil cooler in the mean time. _________________ 1980 924 Turbo
james911996
Posted: Thu May 12, 2022 12:35 am Post subject: |
Thanks both.
I should have started with this, engine is standard other than
- hotter cam
- there is an oil cooler
Regs limit any engine modes to minimum.
SO you think stock system should be enough and this is likely an issue within the cooling system rather than timing or air/ fuel mixture? |
Posted: Thu May 12, 2022 1:05 am Post subject: |
| james911996 wrote: | Thanks both.
- hotter cam
I've done 12h racing and 2x 45 minutes for example in 28 degree heat with bog standard cars, without any oil cooling, the needle didn't move. Its the same rad as a 924 turbo which put alot more heat into the system. Double checking the timing and fuelling properly is definitely a good idea anyway, those should always be in perfect order on a track/race car. _________________ 1980 924 Turbo
Joined: 28 Feb 2008 Posts: 1423 Location: Washington DC area
Posted: Thu May 12, 2022 5:25 am Post subject: |
Same with both of my 924 race cars. 41 degrees total advance and higher compression pistons. I have a stock 924 radiator in both cars with no special ducting and temps are below the middle of the gauge while running. I have a switch on my two front fans that turn them on when I come into the pits to keep the engine below the half way mark.
If you have a stock 924 radiator, it may be slightly (or more) blocked. You can take it out and have it rodded (cleaned) and flow tested or replace with a 944 radiator. The 944 radiator is about 1 inch thicker and involves some finagling to install. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
Posted: Thu May 12, 2022 6:03 am Post subject: |
Agreed, stock 924 rad should be fine for this if it's working right - which seems like maybe not, perhaps a system flush or the like are in need. _________________ Vaughan Scott
james911996
Posted: Thu May 12, 2022 8:17 pm Post subject: |
Ok. I have a rolling road tune for fueling and timing booked in a couple of weeks.
So in the meantime it sounds like we should make sure the cooling system is flowing fully.
- radiator: cost of returning the existing likely to be more than an aluminium 944 rad, which I’ve been told can be fitted with a few brackets. They are less than 150 quid here in the UK. So might do that just to have peace of mind the rad is good
- thermostat: I have the fan on a switch on the dash like fifty50Plus, so would it make sense to just remove the thermostat for caution? (I’m not actually sure if it’s still in the car)
- can the heater matrix be a blocking point for cooling?
- then fill the gaps around the rad to make sur it is getting all the air: this is a nice to have but not a must have if the system is flowing right
- anything else to look at? |
Posted: Thu May 12, 2022 8:43 pm Post subject: |
Leave the thermostat in - replace with new if concerned about its function.
We also run a dash switch, in parallel with the stock rad fan switch, kick that on during the cooldown lap just to be sure (mainly to not forget it later). _________________ Vaughan Scott
james911996
Posted: Fri Jun 03, 2022 12:13 am Post subject: |
quick update here.
Was due to go on the rolling road and wouldn't start.
After some investigation it had a blown head gasket and the head needed to be skimmed back to flat.
Getting reassembled now and hopefully all ready for a test day on Tuesday.
James |
