MikeDanger
Posted: Sun May 22, 2022 4:13 pm Post subject: going to rich off the line, can't figure it out. |
Hey Guys, got another CIS problem.
So when accelerating it goes to about 10A/F +/-
again, i Have a dual adjustable WUR, and and tried, about 300 settings (I have driven around my neighborhood and pulled over, get out, adjust, drive 100 yards, and repeat 1000 times!)
I have adjusted the pressure correctly and tried variations from there with NO affect.
Basically when I try to accelerate from a stop, it goes way too rich at about a 1/4-1/3 throttle.
Now it starts to come back as the car speeds up,(obviously im backing out of the throttle as the car is accelerating) .
Cruising its ok, but when I go to speed up, it drops.
I set the A/F at idle, both with the Meter mixter screw, and the Allen at the bottom of the WUR.
I just put in a stock non adjustable WUR and it still did the same thing, so Im leaning away from the WUR.
so heres the short list of whats been done related to fuel/intake:
CIS diaphragm replaced
Injectors cleaned and
new fuel filter and pre fuel pump filter
all new silcone vac lines, and intake hoses.
new O2 sensor
new fuel pump.
Rebuilt and modified WUR _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Sun May 22, 2022 4:18 pm Post subject: |
Im am i right thinking it can't be a Vac leak, because then it would go lean right?? _________________ It was either this or a giant box of legos |
kondzi
Posted: Sun May 22, 2022 5:47 pm Post subject: |
Disconnect the vaacum/ boost hose from WUR and see what happens.
The bottom hex screw adjust amount of richness under boost. So first try to sort out when no vaacum / boost condition is applied. _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Sun May 22, 2022 11:25 pm Post subject: |
When you make an adjustable WUR like that you can push it one way with the screw, but you still have to tap the valve body back the other way don’t you?
Are you doing that?
Moving the valve body in and out of the WUR is what sets control pressure right?
And the installed screw pushes it out so you don’t have to disassemble it every time you want to change it in the out direction..
But to change it back to the in direction, you have to tap it back in with a hammer don’t you?
Moving the valve body out would lessen the tension of the spring on the valve lowering control pressure right?
Tapping it back in would raise control pressure I believe..
Are you confirming your pressure changes with a gauge? _________________ 80 Turbo - Slightly Modified |
MikeDanger
Posted: Mon May 23, 2022 11:17 am Post subject: |
| kondzi wrote: | Disconnect the vaacum/ boost hose from WUR and see what happens.
The bottom hex screw adjust amount of richness under boost. So first try to sort out when no vaacum / boost condition is applied. |
already did that.
Actually no the hex screw doesnt really do that. That is controlled by the large diameter spring under the diaphragm
the hex screw adjusts the WARM control pressure. _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Mon May 23, 2022 11:22 am Post subject: |
| Fasteddie313 wrote: | When you make an adjustable WUR like that you can push it one way with the screw, but you still have to tap the valve body back the other way don’t you?
Are you doing that?
Are you confirming your pressure changes with a gauge? |
No you dont have to tap the valve body, if you use the hex scew on the bottom. I can fully control the Warm pressure with that.
yes of course I have a gauge, as mentioned in the list. _________________ It was either this or a giant box of legos |
Posted: Mon May 23, 2022 11:24 am Post subject: |
Must be a different WUR mod than I am thinking then.. _________________ 80 Turbo - Slightly Modified |
MikeDanger
Posted: Mon May 23, 2022 1:47 pm Post subject: |
kondzi
Posted: Mon May 23, 2022 4:36 pm Post subject: |
I think you’re doing it wrong. Take a look at the diagram of WUR and try to understand the physics / forces / tensions on internal parts. Moving the round blocks in and out of the WUR body is affecting the pressures. One affects the other, the other does not affect the first. Then add to that the hex screw at bottom, which IS FOR LIMITING RICHNESS UNDER BOOST. Hook up pressure tester and push in / out the blocks. Set it to the values from Service manual. Then add vaacum / boost with a pump / syrgine and check on the pressure tester how it’s affecting the pressures.
EDIT: see my thread for manual control pressures.
https://www.924board.org/viewtopic.php?t=43790&postdays=0&postorder=asc&start=15 _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
MikeDanger
Posted: Tue May 24, 2022 6:14 pm Post subject: |
Im pretty sure its NOT the WUR. I can make the car very lean (warm or cold) and it still goes to 10A/F when accelerating, gong to or above 3k
the vac line to the WUR is disconnected, again NO difference.
what else would make it go rich??
what if the decel valve was bad?
this is sort of the opposite of a Vac leak. _________________ It was either this or a giant box of legos |
Posted: Tue May 24, 2022 9:57 pm Post subject: |
Boost leak would make it go rich just as you say..
The opposite of a vacuum leak..
Decel valve only if it was leaking to atmosphere.. _________________ 80 Turbo - Slightly Modified |
MikeDanger
Posted: Thu May 26, 2022 2:42 am Post subject: |
well... maybe a clue?
I talked to a local shop... and he mentioned how I should set the idle A/F with the O2 disconnected.
So I did that. initial start up was at 11.6, where it pretty much stayed. so I adjusted at the distributor/meter to 14.5.
Now when I rev the engine it only goes to 12.5 (in the garage, havent driven yet).
So what does that say?? couldn't burn out a new o2 sensor in 20 miles could I? _________________ It was either this or a giant box of legos |
Posted: Thu May 26, 2022 3:10 am Post subject: |
He is right..
Or set it with the dwell meter method..
That means you has the AFR screw set way too rich for its standard base tune.. _________________ 80 Turbo - Slightly Modified |
MikeDanger
Posted: Thu May 26, 2022 8:40 am Post subject: |
| Fasteddie313 wrote: | He is right..
That means you has the AFR screw set way too rich for its standard base tune.. |
it was only a quarter turn to get it to 14.5 _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Fri May 27, 2022 4:20 pm Post subject: |
was doing a bit of reading on o2 sensors, saying the need outside refernce air, amont other things.... so I decided to get under and have a look just to see whats what.
and I find the outside of the sensor is covered in oil. oil seems to be leaking right on to it. and the end where the wire goes in, has drops of oil on it (rather than just a thin coating.) could oil have gotten IN TO the sensor??
I pulled out the sensor it has a coating of soot on it, but I assume that from running rich, im sure there is slight oil burn, but it can't be bad enough to kill a new sensor in less than 50 miles.
