Gatornapper
Posted: Sat Oct 30, 2021 12:57 pm Post subject: '80 931 in storage for 17 years - Clutch pedal on floor |
Hope to pick up a really sweet '80 931 that has been well-stored for 17 years (weatherproof building under car cover). 58k original miles.
The clutch pedal is on the floor. I am an old mechanic with a full shop.
Of course I'll fill reservoir with fresh fluid and pump the pedal and see what happens, look for leaks. But if I find none -
Simple question: In everyone's experience here, is this more likely to be the Master cylinder? or the slave cylinder?
Just want to save some time on which one I rebuild first. I know - I should just rebuild both.......
TIA for the help.
GN |
jazz guy
Posted: Tue Nov 02, 2021 5:57 am Post subject: |
Common issue and the culprit is most likely the slave. Happened on two of mine. Both times the slave cylinder needed a rebuild or replacement. _________________ '81/'81/'82 |
chuck21401
Joined: 20 Feb 2005 Posts: 526 Location: Annapolis, MD
Posted: Thu Nov 11, 2021 2:23 am Post subject: Re: '80 931 in storage for 17 years - Clutch pedal on floor |
Gatornapper wrote: | Hope to pick up a really sweet '80 931 that has been well-stored for 17 years (weatherproof building under car cover). 58k original miles.
TIA for the help.
GN |
In my case I needed to replace both, plus the hydraulic hose.
A number of vendors offer the parts as a kit.
I also replaced the braided line from the reservoir to the master cylinder.
More details and pics here:
https://www.924board.org/viewtopic.php?t=44402&highlight=master+cylinder
I found the best part of the job to be disconnecting the MC from the clutch pedal arm. It takes some effort to get up under the dash to reach everything.
Good luck. Any pics of your 931? Low mile original cars are rare birds these days.
Edit: Nevermind....I saw the picture of you car on the other thread. Very nice...enjoy. _________________ 1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler |
Gatornapper
Posted: Sat Nov 13, 2021 2:09 am Post subject: Re: '80 931 in storage for 17 years - Clutch pedal on floor |
Thanks Chuck.
Master cylinder totally shot - never seen one so bad. piston rod totally loose.
I am small so squeezing under to disconnect rod is difficult, but I can do it.
My bigger concern is how to get to master cylinder......seems almost inaccessible unless I remove brake master cylinder and booster.
Hoping slave is ok, but will replace lines as well and find out.
Car has 58k miles, proven. So maybe slave is ok.
Surprised master cylinder went out so early.
GN
chuck21401 wrote: | Gatornapper wrote: | Hope to pick up a really sweet '80 931 that has been well-stored for 17 years (weatherproof building under car cover). 58k original miles.
TIA for the help.
GN |
Edit: Nevermind....I saw the picture of you car on the other thread. Very nice...enjoy. |
chuck21401
Posted: Sat Nov 13, 2021 11:22 pm Post subject: Re: '80 931 in storage for 17 years - Clutch pedal on floor |
With my car both the master and slave were replaced in recent history but both needed to be replaced again. From what I understand, it's not the mileage so much as moist air entering the reservoir system and then being absorbed into the hydraulic fluid. Some discussion on this thread: https://www.924board.org/viewtopic.php?t=34855&sid=00e00329bac141c05b673bfa0499915e _________________ 1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler |
Gatornapper
Posted: Sun Nov 14, 2021 11:28 am Post subject: Re: '80 931 in storage for 17 years - Clutch pedal on floor |
Watched videos today on replacing both master & slave - pretty cut & dried. Master very difficult to reach, but possible obviously. Slave much easier once starter is removed.
So to have a good baseline on the car, I'm replacing both. Will closely inspect the line and replace it too if it looks weak.
GN
With my car both the master and slave were replaced in recent history but both needed to be replaced again. From what I understand, it's not the mileage so much as moist air entering the reservoir system and then being absorbed into the hydraulic fluid. Some discussion on this thread: https://www.924board.org/viewtopic.php?t=34855&sid=00e00329bac141c05b673bfa0499915e |
Gatornapper
Posted: Sun Dec 05, 2021 12:22 am Post subject: |
Clutch master cylinder OUT, picking up new one today.
Slave cylinder on way from Pelican and will be here Thursday.
GN |
iambhooper
Joined: 30 Dec 2021 Posts: 13 Location: Greensboro NC
Posted: Mon Jan 03, 2022 12:27 pm Post subject: |
Gatornapper wrote: | Clutch master cylinder OUT, picking up new one today.
GN |
Did that fix the problem? _________________ Hoop
87 924s (1st Porsche) project
1986 Fiero Gt
1990 DA Integra STL
And some other things |
MikeDanger
Posted: Mon Jan 03, 2022 5:09 pm Post subject: |
You should check the Brake MC for leaks, your Booster could be full of fluid, Also check the Firewall for cracks at the Clutch MC, before your firewall blows out! _________________ It was either this or a giant box of legos |
