McGyver
Joined: 24 Feb 2009 Posts: 354 Location: Jelenia Gora - Poland
Posted: Tue Feb 26, 2013 6:43 am Post subject: |
I got mine fried relay fixed and upgraded so now it should prime fuel pump for 1-2 seconds after power is on - turn the key to on position... and should work after engine crank.
I had to test in now in car but it seems to work fine. And I can confirm that KAE relay doesn't have prime pump on function ... there's to simple board inside which only allows relay work if it gets signal from coil.
I post some more photos etc when I test it. _________________ 931 82' - 5000km after full engine rebuild
SOLD: 924 81' N/A- with turbo gearbox "dogleg" - great but mysterious car
www.mauser98k.internetdsl.pl - if someone like german rifles (English version avalible) |
db
Posted: Sat Dec 11, 2021 12:10 am Post subject: 433 906 059 relay |
I read the thread and ache. I am having the same problem with a 1979 924. When wired at 12v on 15 with earth on 31, the relay does nothing. Ticking 12v on pin 1 does nothing. When I open the relay and touch the PCB past the 47 kOhm resistor following pin 1, the relay closes for half a second, so the 555 timer chip and the relay itself are fine. The 47 kOhm resistor shows 47 kOhms. I am at a loss. Does anyone have any wisdom on this? Or, a spare relay?
BTW, jumpered 87-30 turns the pumps constantly when I connect the battery and the car starts.
Thanks for reading and for keeping up the enthusiasm for old wrecks |
Gatornapper
Posted: Sun Dec 12, 2021 12:56 am Post subject: Re: 433 906 059 relay |
I found 2 - Bosch relays in the glove compartment of my car that I don't think fit it - but not sure yet. A Porsche expert says they are FPR's for 79 and earlier 931.
Haven't tested yet as I'm not quite sure what terminals 15, 31 and 31b get what voltage to work - they go to a transistor in the relay, and each has an external 16a fuse on the top of the relay. They both have the same pin-outs and schematic printed on them.
I think 31 is to ground.
One is an 896321 and the other is 89 6494. Once I verify they do not go in my car, I'm willing to pass them on. If they are NLA, I'd want a little something for them, maybe half of what they are worth.
GN
db wrote: | I read the thread and ache. I am having the same problem with a 1979 924. When wired at 12v on 15 with earth on 31, the relay does nothing. Ticking 12v on pin 1 does nothing. When I open the relay and touch the PCB past the 47 kOhm resistor following pin 1, the relay closes for half a second, so the 555 timer chip and the relay itself are fine. The 47 kOhm resistor shows 47 kOhms. I am at a loss. Does anyone have any wisdom on this? Or, a spare relay?
Thanks for reading and for keeping up the enthusiasm for old wrecks | [/img] |
Eliza
Joined: 17 Aug 2015 Posts: 174 Location: Prov. Utrecht, The Netherlands
Posted: Mon Dec 13, 2021 11:19 pm Post subject: |
db,
is your car a MY 1979 or 1980? If 1980, you need a 433906059 FPR ( or 3.300.300 from KAE or similar ). MY 1979 needs a different one IMO, it should have its own fuse.
Is it the priming that doesn't work, or doesn't your car start with the relay you have?
Just ticking pin 1 won't do, the relay expects a pulse from the neg. side of the coil. The wire is the same that hopefully makes your tach bounce slightly while cranking.
Eliza
EDIT: Checking PET shows FPR 433906059 for MY 1979 as well. The switch from the older one was made in MY 1978. _________________ 1985 924 NA RoW
1981 931 S2 RoW |
