B2524
Posted: Sat Oct 23, 2021 1:43 am Post subject: My Roadkill 924 |
I picked up this 77 924 from a wrecking yard and plan on making improvements to make it an auto-X car and somewhat street legal.
Key words are cheap and fun.
The story I got was that it ‘Ran when parked’!
So far I’ve found that the oil is fresh as is the filter, the engine looks clean inside the filler hole, the transaxle looks fresh and the car was complete minus the radio.
I ran a compression test yesterday and the motor is good, enough.
I need to get under the car still but I’m hoping that they did the clutch when the transaxle was worked on. I know wishful thinking but you never know.
Clock says 88,xxx miles.
I’m planning on adding a lot of lightness to the car along with 5 lug suspension and Weber’s.
I see that posting an image is not easy so I will post this on pelican. _________________ It’s a sickness. |
