Decking block
Juho
PostPosted: Wed Aug 25, 2021 11:08 pm    Post subject: Decking block Reply with quote
How much you can deck the block? Timing belt issues? I need to shave off 1.5-2.5mm for desired compression.
safe
PostPosted: Thu Aug 26, 2021 6:50 am    Post subject: Reply with quote
Yes, you need a shorter belt. One tooth I think.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
Juho
PostPosted: Thu Aug 26, 2021 3:13 pm    Post subject: Reply with quote
https://www.autodoc.fi/contitech/1210771
Yeah volvo guys get 1 teeth shorter when decking blocks +2mm.
Found this should work right?
safe
PostPosted: Thu Aug 26, 2021 5:54 pm    Post subject: Reply with quote
Not sure. I have friend who has decked the block 1.5mm, I know he runs a shorter belt, but I don't know where he gets it. Its a bit tight to get on the engine, you really don't have to tension the tensioner...
Porsche 931 -79
Juho
PostPosted: Thu Aug 26, 2021 6:30 pm    Post subject: Reply with quote
Could you ask him what belt he runs?
safe
PostPosted: Thu Aug 26, 2021 7:14 pm    Post subject: Reply with quote
Yes.
He says,1 tooth shorter, he gets them from Mittelmotor.
Mottelmotors webshop really really sucks if you cant find it, so you might have to call them or email, but they suck at email too...
Porsche 931 -79
Juho
PostPosted: Thu Aug 26, 2021 9:21 pm    Post subject: Reply with quote
safe wrote:
Yes.
Have to email them, they might just be selling audi belts at a higher cost?
Juho
PostPosted: Thu Aug 26, 2021 9:31 pm    Post subject: Reply with quote
Found it on the shop, 50 euros for one belt might have to look in to the audi belts because i have a feeling they might be selling them at a higher cost.
TJC
PostPosted: Fri Aug 27, 2021 12:36 am    Post subject: Reply with quote
It would seem to me that perhaps the best source would be to contact your favorite belt manufacturer directly rather than going through some middleman to discover which size belt you need to purchase. They would most likely have all the specifications and with a little work they may provide you with the proper belt part number so you may go shopping for the best deal.
Then once you know the standardized belt number and are sure that it works properly you may tell the world...or keep it to yourself, buy up a supply of shorter belts and resell them as at a huge profit to compensate for the bit of time and effort put into sourcing them in the first place...like Mittlemotor, perhaps!
'95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com
DZGunner
PostPosted: Mon Oct 04, 2021 3:49 am    Post subject: Reply with quote
You keeping the stock internals with this compression ratio upgrade?
1979 924 (Daily driver EFI)
1979 924 Sebring
1977 924
1977 924 (Parts)
Juho
PostPosted: Mon Oct 04, 2021 3:12 pm    Post subject: Reply with quote
no, 931 head vw flat tops, forged rods
