Posted: Thu May 20, 2021 2:43 pm Post subject: Fuel Accumulator Threads/Fittings |
Can anyone easily tell me what the threads/fittings are on the 931 fuel accumulator?
I am intending to bypass/delete mine and it would be very nice for me to be able to just order the correct fitting(s) I need to reconnect the 2 lines to eachother when I get home, so I don't have to tear it out, figure it out, and then run all over the place trying to find what I need..
Could save me a lot of time if someone could just tell me what I need so I can order it to be waiting for me to do a 5 minute job instead of an all day job..
Thanks in advance.. _________________ 80 Turbo - Slightly Modified |
MOTANUL
Joined: 19 Nov 2018 Posts: 214 Location: ROMANIA BUCHAREST
Posted: Sun May 30, 2021 9:22 am Post subject: |
As far as I know, they are not all the same. I also met some fuel accumulator with the same diameter and others with a larger diameter and a smaller one.
If they have not been dismantled for a long time, they are very likely to be rusty - blocked. It is more likely to break than to be easily disassembled.
But why do you want to eliminate it? Is fuel accumulator broken? 5 minutes is very optimistic. _________________ 1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
sold Porsche 924 NA 1979 |
Posted: Mon May 31, 2021 11:08 pm Post subject: |
I want to delete it because it has developed a small leak and it is no longer necessary on my car..
Figure if I can find the correct fittings I could just remove it and splice the 2 lines together where it used to be.. _________________ 80 Turbo - Slightly Modified |
