Is there a list/picture of the terminals and the connections
gorogorogo
PostPosted: Fri Apr 09, 2021 11:58 am    Post subject: Is there a list/picture of the terminals and the connections Reply with quote
I am bad at electricity. I'm in the middle of trying to make blower motor work (it isn't getting power for some reason). While I was trapped under the dash I noticed that there was a yellow/white wire with a female end that was disconnected. It's probably supposed to go to the "G" block, but I've been unable to locate it in any diagram. I've also failed at figuring out where it is that the wire goes.
Is there just a list or picture of the central board and the wires that are supposed to come out of it? It looks like the wire runs to the D set of terminals, but I can't tell for certain.
Also is it possible to hook up the early slider control incorrectly? The car is 1978/79 with no AC and single slider. There are only 2 terminals on the top of it. On terminal 1 there are two brown wire parallel on single connector. On terminal 2 the is a V connector thing. It has a mysterious orange wire (which I guess is supposed to go to a resistor located somewhere) and then the other of the two leads that come out of the motor.
Thanks!
PostPosted: Sat Apr 10, 2021 3:07 am    Post subject: Reply with quote
The diagram is on pg.262 of my Haynes manual. Pin D19 of connector D on the main panel (a black/red wire), fuse 10 (16A), violet wire to motor (+), yellow wire from motor (-) connects to the switch and a 10 ohm resistor wire (or wire with 10 ohm resistor on it somewhere), two brown wires of different sizes out of the switch to ground.
!tom
PostPosted: Sat Apr 10, 2021 3:39 am    Post subject: Reply with quote
Smoothie's back! Good to hear from 'ya.
78 924 NA
5-lug
PostPosted: Sat Apr 10, 2021 4:13 am    Post subject: Reply with quote
Smooth Dog!
And isn't that your green turbo making a "car of the day" appearance, as well?
Hmmmm
PostPosted: Sat Apr 10, 2021 10:41 pm    Post subject: Reply with quote
Hey! Let's focus and stay on topic. ๐Ÿคจ
But, hi! ๐Ÿ™‚
