Can you push start a 924?
MikeDanger
PostPosted: Mon Jan 04, 2021 12:26 pm    Post subject: Can you push start a 924? Reply with quote
So im going to go ahead and put in a super-capacitor "battery" should save about 30lbs of weight....But only gives you a couple tries to get the engine started.
SOoooo, if necessary can a 924 be push started? Im just not sure how well CIS would work with that method.
PostPosted: Mon Jan 04, 2021 6:21 pm    Post subject: Reply with quote
Without power to the fuel pump im not sure how easy that will be. Isn't it a better solution with a Lifepo4 battery, not much heaver, and i can crank for a looong time if i need to.
PostPosted: Mon Jan 04, 2021 10:04 pm    Post subject: Reply with quote
Yes, it absolutely can.
But I have been very happy with the Antigravity Batteries LiPo in my P2... excellent durability. Definitely get the matching charger.
PostPosted: Tue Jan 05, 2021 12:21 am    Post subject: Reply with quote
I know for a fact you can but its not fun. Do it in 2nd gear BTW or at least thats what I did in my 80 931
Raize
PostPosted: Tue Jan 05, 2021 9:49 pm    Post subject: Reply with quote
Best if you jumper the FPR.
