Posted: Sat Oct 17, 2020 12:49 am Post subject: Driveline Install |
I've always wanted to install the entire driveline as an assembly, factory-style, and I finally did it.
It was ridiculously easy with a jack under the trans and a cherry picker raising the engine. For a serious restoration project, I think I'd recommend the procedure as the standard approach. _________________ Toofah King Bad
Posted: Sat Oct 17, 2020 4:08 am Post subject: |
Please detail!
I’ve always wanted to more like lift the body off, but how did ya do it? _________________ 80 Turbo - Slightly Modified |
kondzi
Posted: Sat Oct 17, 2020 6:29 am Post subject: |
Photos / Videos please  _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Sun Oct 18, 2020 2:54 am Post subject: |
Sorry, no pics. Ever since Photobucket screwed the universe, I've stopped documenting projects like I used to.
The process was easy...I raised the tub on for a jack stands as high as it would go. I then slid the engine under the nose of the car and bolted up the torque tube to it, with a little bit of help from a floor jack raising the transmission end. I then bolted on the gearbox.
Once everything was together I raised the engine end of the assembly with a cherry picker and raised the transmission end with a floor jack. It was ridiculously easy. _________________ Toofah King Bad
jacobroufa
Posted: Tue Oct 20, 2020 2:35 am Post subject: |
O_O Wow that's cool. Sure looks simpler to drop/reinstall the whole kit and kaboodle than to deal with each part separately, contorting hands and limbs to get those last two upper bolts... _________________ 1980 Porsche 931
1981 Porsche 924 Weissach |
Posted: Sat Oct 24, 2020 5:22 am Post subject: |
Indeed, and so much easier to align the clutch when the engine and tube are on the ground. _________________ Toofah King Bad
