Hood (Lid) Pin (lock) area with Rust (PLEASE CONTRIBUTE)
MOTANUL
PostPosted: Fri Jan 31, 2020 6:44 am    Post subject: Hood (Lid) Pin (lock) area with Rust (PLEASE CONTRIBUTE) Reply with quote
I noticed that in the area of the lock many hoods have rust (Turbo or NA). My car is no exception. How can it be repaired?
The rest of the hood looks better than many SH hoods. It is rust free.
1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
sold Porsche 924 NA 1979
MOTANUL
PostPosted: Mon Feb 03, 2020 4:09 am    Post subject: Reply with quote
I did archeology in paint. 4 layers of paint (two red and two gray metallic)
I cut some of the metal sheet. I still have a bit to cut. Inside is exactly what I expected.
I'm waiting for the drills for removing the welding points given in the factory.
I ordered 3m weld thru. I also have rust inhibitor.
The plan is to remove the strong corroded metal. I will treat the surface corroded metal with a rust inhibitor.
In center: new sheet of metal and 3m weld thru.
MOTANUL
PostPosted: Thu Feb 13, 2020 11:46 pm    Post subject: Reply with quote
The hardest part is ready! The hood is ready made of paper.
Now comes the easy part to make and a weld metal.
PostPosted: Tue Mar 03, 2020 12:03 pm    Post subject: Reply with quote
Nicely done! Did you finish???
MOTANUL
PostPosted: Wed Mar 04, 2020 7:13 pm    Post subject: Reply with quote
Prep for paint. Almost ready
The painter is very busy.
PostPosted: Wed Mar 04, 2020 9:30 pm    Post subject: Reply with quote
Very nice!
Check for rust starting where the naca duct is...i remember i fixed some rust there when i had the car....have a look now before painting if there isnt any rust going on beneath the paint.
MOTANUL
PostPosted: Thu Mar 05, 2020 1:24 am    Post subject: Reply with quote
On the other side was rust in the naca duct area. I cleaned the area well and gave it rust inhibitor. (a factory welding point with rust problems around).
MOTANUL
PostPosted: Sun Mar 15, 2020 6:04 am    Post subject: Reply with quote
the hood ia back on the car. It's looking pretty good.
Now I send the seats and door panels to reupholster them.
MOTANUL
PostPosted: Sun Mar 15, 2020 6:08 am    Post subject: Reply with quote
PostPosted: Sun Mar 15, 2020 7:12 am    Post subject: Reply with quote
nice job !
cant wait to see the interior done as well.
PostPosted: Sun Mar 15, 2020 10:08 am    Post subject: Reply with quote
I second that! Nicely done!
Did you paint it? I ask only because the first rule of thumb to show off your paint job is to not do it in doors under fluorescent or similar lighting but it really looks good
MOTANUL
PostPosted: Sun Mar 15, 2020 8:22 pm    Post subject: Reply with quote
The hood was painted by a professional painter (cabin and special support for rotation). In the repaired area there are portions that look better than the rest of the bonnet. I have a straight beam in the garage ceiling and I studied how it is reflected in the hood in different areas.
The hood has received a generous layer of clear coat (lacquer) so it can be polished further more.
I hope the hood is a closed chapter.
