NACA Duct measurement request
Qik Nip
PostPosted: Fri Oct 05, 2018 12:07 am    Post subject: NACA Duct measurement request Reply with quote
Can anyone here with a 924 Turbo sitting in their garage do me the favor of measuring the width, depth and length of the NACA vent in the hood? I'm considering "grafting" one on the driver's side hood of my land speed (naturally aspirated) 924. Thanks
Rick
'79 NA 924 Land Speed Car
Great Lakes SCCA SM points champion '09,'10,'11
PostPosted: Fri Oct 05, 2018 3:23 am    Post subject: Reply with quote
Can check mine when I get home, if no-one beats me to it...
Qik Nip
PostPosted: Fri Oct 05, 2018 5:10 am    Post subject: Reply with quote
Thanks. So far you're it!
Rick
PostPosted: Fri Oct 05, 2018 5:44 am    Post subject: Reply with quote
Im curious, why do you want it?
PostPosted: Fri Oct 05, 2018 7:11 am    Post subject: Reply with quote
length 15", width 7", depth 1.5"... add maybe 1/2" all around for the "outside" dimensions for grafting on the hood. Maybe not super-precise, but should give you some idea of the general size...
Qik Nip
PostPosted: Fri Oct 05, 2018 9:13 am    Post subject: Reply with quote
Cedric:
I hope to get cooler air into the engine while avoiding the added air resistance created by a traditional hood scoop. The air under the hood of a fast moving car is subject to tremendous turbulence and I fear is resulting in each of the four carburetor throats receiving differing quality and quantities of air. I plan to plum the NACA vent into an air box enclosing all four of the Weber throats to both "quiet" it and deliver cooler (therefore more dense) air to the engine.
At least that's the plan!
Rick
Qik Nip
PostPosted: Fri Oct 05, 2018 9:14 am    Post subject: Reply with quote
Thanks Vaughn!
gegge
PostPosted: Sat Oct 06, 2018 5:22 am    Post subject: Reply with quote
Remember that the hood is a low-pressure zone. Why not try connecting the carburator plenum directly to the batterybox? That is high pressure! Poor man´s turbo
Carl Fredrik Torkildsen
PostPosted: Sun Oct 07, 2018 5:35 am    Post subject: Reply with quote
Pegasus Racing has some NACA ducts that are meant to be fit into side windows, not sure about the size as far as airflow. I made a bucket to fit in the driver side headlight bucket somewhat similar to the fixed headlight conversion. Then I found an 3" tapered inlet inlet at summit racing. I haven't quit figured out how to install it neatly , yet, as it is not a refined part and I have the stock steel front panel. It probably would increase the drag. I still have the mold if interested.
I recall seeing your photo's and if you have the Dprod front end from CCP in Florida you might look at using the lower brake air duct if you haven't sealed it off.
Mike
'67 MG Midget Dp
PostPosted: Sun Oct 07, 2018 10:21 pm    Post subject: Reply with quote
Agreed, ABS plastic NACA ducts can be cheaper; Pegasus is one of the more expensive places to buy. Try Hoerr Racing Products (HRPworld.com) or Summit or JEGS:
https://www.hrpworld.com/shop-by-category/brake-system/brake-and-aeroducting/bumper-ducting.html
Qik Nip
PostPosted: Mon Oct 08, 2018 5:51 am    Post subject: Reply with quote
Now that's interesting. To those wondering about his low pressure comment, NACA vents don't work well unless they are positioned in a high pressure area. That does however bring into question the use of the NACA on the turbo 931... Although a blower pulls air and perhaps therefore doesn't need a forced feed...
Anybody got the lowdown on that issue?
Rick
poor-sche
PostPosted: Mon Oct 08, 2018 12:59 pm    Post subject: Reply with quote
The naca duct dumps air directly in front of the battery box and down onto the exhaust manifold. Its purpose is for cooling and looking cool.
The factory air box pulls air from the opposite corner of the engine bay (next to the drivers side head light).
PostPosted: Mon Oct 08, 2018 6:28 pm    Post subject: Reply with quote
Not sure the that the NACA 'dumps' air.........remember air also flows under the car. My understanding is air is being drawn out of the back of the engine tray and under the car. This draws air into the engine bay via the NACA (and nose vents in the turbo). This keeps the engine bay and more specially with the NACA, the exhaust side flowing with cooler air. The NACA adds to the engine bay air flow and does not 'scoop' air into the bay.
gegge
PostPosted: Tue Oct 09, 2018 4:41 am    Post subject: Reply with quote
Since the NACA is situated right above the exhaust/turbo and hot air is rising, in addition to a low pressure zone...
A NACA duct is only working properly in high speed, that is MACH speed. The ram pressure or air flow volumes is poor compared to protruding scoops. The trade-off to drag I guess.
I belive NACA was a cool design feature in 70´car design. The Countach, Espada, Montreal, Mustang and 931 to mention a few. And F40 of course, ten tears later.
PostPosted: Tue Oct 09, 2018 9:33 am    Post subject: Reply with quote
NACA ducts work very well on race cars to put air in the cockpit for driver cooling. Adding flexible tubing allows us to aim the air wherever we want.
1981 924 Turbo sold
1982 924 Turbo sold
