Joma
Posted: Sun Dec 25, 2016 11:26 pm Post subject: |
what style injectors fits the fuel rail,
short 40mm
normal 50mm
long 60mm |
canyonblaster
Joined: 20 Aug 2012 Posts: 391 Location: Denver, CO, USA
Posted: Wed Dec 28, 2016 2:31 pm Post subject: |
Thanks Rasta! _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
Daily Driver P cars: 2008 Cayenne GTS, 2013 Cayenne GTS |
Posted: Tue Jan 17, 2017 10:15 am Post subject: |
At LONG last. Our first run of production fuel rails. Supply should now be secure for as long as I'm in business
First, the pix:
It'll be another week or so before I can provide photos of a rail installed on an engine.
Assembly includes
Aluminum fuel rail, clear anodized so it is safe to use with any percentage of ethanol-based fuel.
QTY 2 mounting brackets (stainless steel) with fasteners
QTY 2 black anodized fittings (-8AN Flare to AN Straight Cut Thread 3/4-16 with O-Rings)
QTY 1 black anodized plug for the fuel pressure port (1/8-27 NPT)
Pricing: $235 + shipping
These will be going up on the site next week or so. In the meantime, PM me for purchase requests. If you don't like the black fittings, you can provide your own or PM me for other options. _________________ erstwhile owner of just about every 924 variant ever made |
Kenodog
Posted: Wed Jan 18, 2017 1:16 am Post subject: |
Hey Dan, be careful using stainless steel brackets on an aluminum head. Galvanic corrosion will F you in no time flat if there is no insulating layer between the two.....those two metals do not like each other.
Super nice bracket though, hats off to you !
Me _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Posted: Wed Jan 18, 2017 1:41 am Post subject: |
| Kenodog wrote: | | Hey Dan, be careful using stainless steel brackets on an aluminum head. Galvanic corrosion will F you in no time flat if there is no insulating layer between the two.....those two metals do not like each other. |
Anodizing to the rescue!
http://metalfinishingsltd.co.uk/articles/prevent-galvanic-corrosion-anodising/
| Quote: | | Super nice bracket though, hats off to you ! |
Joined: 29 Jul 2001 Posts: 9082 Location: Royal Oak, MI, USA
Posted: Wed Jan 18, 2017 4:09 am Post subject: |
Maybe talking about where they bolt to the intake? _________________ Vaughan Scott
Posted: Wed Jan 18, 2017 4:34 am Post subject: |
| 924RACR wrote: | | Maybe talking about where they bolt to the intake? |
The big concern there would be the fasteners, so if you're using the oem studs and nuts to which the brackets mount, there shouldn't be any issue. If you're worried about where the hole in the bracket and the bracket surfaces touch the intact, a light coating of copper anti-seize should prevent galvanic corrosion. _________________ erstwhile owner of just about every 924 variant ever made |
Kenodog
Posted: Wed Jan 18, 2017 5:55 am Post subject: |
I was. You already mentioned the rail was anodized. I would be more inclined to use a rubber grommet or nylon washed. Mi dos centavos..
Snow Mexican Me _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Wed Jan 18, 2017 6:27 am Post subject: |
Yeah, I was sorta thinking I'd do similar - actually, my manifold is painted anyway, but thin nylon washers could be enough... or yeah, antisieze...
(rather deal with that than aluminum brackets fatiguing!) _________________ Vaughan Scott
motormouth
Posted: Wed Jan 18, 2017 7:26 am Post subject: |
We went over galvanic corrosion in an engineering class and there is a chart that shows what is called "Galvanic Series." Basically, the farther apart the two metals are in the galvanic series, the more susceptible they are to corrosion when they are next to each other--the result of an anode and cathode reacting.
There is a common misconception when using metals that are thought to not corrode as bad interacting with each other. Take the two metals mentioned, for example, aluminum and stainless steel. While both of these have good corrosion resistance on their own, they have a large galvanic difference. When coupled, the aluminum acts as an anode, and the stainless steel as a cathode and the aluminum corrodes away.
more info can be found here for those interested:
http://www.ssina.com/corrosion/galvanic.html |
