Qik Nip
Posted: Wed May 11, 2016 9:24 am Post subject: Upper radiator hose source |
I'm in the late stages of the LSR car build and have sucessfully sourced all the cooling hoses except the upper radiator hose (the one with the bleeder valve) and the short molded S shaped thermostat to water pump hose. I could reuse the old ones, but I'd really not like to have to do so. Anyone have a line on either? Pelican, Paragon, Jegs, Summit, Rock Auto, ect are a non starter.
Rick _________________ '79 NA 924 Land Speed Car
Great Lakes SCCA SM points champion '09,'10,'11 |
Posted: Wed May 11, 2016 9:52 am Post subject: |
The S hose is NLA. I would strongly recommend finding something close that you can adapt, as that hose frequently develops pinhole leaks (in my experience), and I wouldn't want to risk a fresh build on an old hose. Unfortunately, I haven't yet had time to chase down a reliable / repeatable aftermarket option.
I wasn't aware that the bleeder hose was NLA, but I believe I may have an extra NOS unit somewhere in my parts bin. I'll do some digging on part numbers and see if I can get a new one. _________________ erstwhile owner of just about every 924 variant ever made |
agfisher
Joined: 09 May 2007 Posts: 484 Location: West Hartford, CT
Posted: Sun Oct 02, 2016 12:13 pm Post subject: |
Hey Dan,
Any news on finding replacements for some of these coolant hoses? Is everything sort of "find what you can" now? _________________ 1977 924 N/A Martini Edition |
Noahs944
Posted: Sun Oct 02, 2016 4:20 pm Post subject: |
I got one you can have for $2000 and take the rest of the car with it!  |
Duncan
Joined: 04 Nov 2002 Posts: 425 Location: Delft, The Netherlands
agfisher
Posted: Sat Oct 22, 2016 11:46 am Post subject: |
Found one at Autohaus for $30 I think just last week. When I get it I'll tell you if it is the right part. _________________ 1977 924 N/A Martini Edition |
Posted: Sat Oct 22, 2016 7:39 pm Post subject: |
That's because Porscheshop buy from Porsche. However they take your money first at a higher price than buying from Porsche direct. Then try to buy from Porsche, they find out it's no longer a available some days or weeks later then refund your money and in the meantime waste valuable spanner time _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Power Tryp
Joined: 16 Apr 2009 Posts: 435 Location: Calgary, Alberta
Posted: Tue Oct 25, 2016 1:30 am Post subject: |
While not cheap Venair makes a substantial coolant hose kit for the NA cars. they delete the metal pipe that runs across but I assume you could just cut the hose to the right length after the curve and clamp it on.
http://www.andysautosport.com/radiator_hoses/porsche_924.html _________________ Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic. |
brian19600
