physicstim
Posted: Mon Aug 17, 2015 9:24 pm Post subject: 931 rust repair |
Hello Members of the Board,
I bought a 931... sight unseen... and well... it's in rough shape.
It runs but the head gasket is blown (compression and leak down test confirm).
The battery tray rusted through the fender, PO drove this way for a while, resulting in the passenger floor rusting to hell. Some of the rust was so bad I was able to rip the passenger seat out of the car with my own two hands!
I'm trying to plan my path forward. Do I repair the rust and head gasket? To repair the rust to I fab sheet metal or find donor panels?
I'm not afraid of the engine work. I'm actually excited to do it. The floors are what have me concerned.
Advice is welcome, and pictures are coming.
thanks,
Tim |
Posted: Mon Aug 17, 2015 10:36 pm Post subject: |
How is the hood, front badge panel with nose vents, rear hatch with spoiler, and the lower front valance? Those are your 931 parts..
I ask because in your case you may be better off finding a donor shell and transferring your parts..
I have done some rust repair myself http://www.924board.org/viewtopic.php?t=39915&highlight= but yours sounds quite extensive and may be a better candidate to swap to another chassis. Most are quite rust free due to very good factory galvanization except for battery leak acid damage and by the sound of it you car likely saw a cracked battery due to freezing or something to get that bad..
I don't know, lets see pics first.. That is just my first thought by the way you describe it.. _________________ 80 Turbo - Slightly Modified |
Posted: Mon Aug 17, 2015 11:10 pm Post subject: |
Sounds like a parts car to me. _________________ Toofah King Bad
physicstim
physicstim
Posted: Tue Aug 18, 2015 9:20 am Post subject: |
| FastEddie and RostaMonsta thanks for your responses... You may not be able to tell from the photos but the body is very straight the floor on the passenger side is pretty bad... I haven't figured out how bad, rust is red, the paint is red, I haven't started sanding away just yet. |
jason c
Posted: Tue Aug 18, 2015 10:46 am Post subject: |
Its a parts car.
Fixing the engine....ok. Fixing the floor.....ok. Fixing the battery area.....ok. Needing to fix all three make it a parts car.
I have done all of these repairs before.....many times.
Do you have all the tools it will take to do the repairs & a place to do it?
You are much better off finding a solid car, there are plenty of them out there....cheap. |
Posted: Tue Aug 18, 2015 12:12 pm Post subject: |
Uggh. I hate rust repairs. Sad to say, it will be cheaper to find another car and making one good one out of two.
On the other hand, this would make yet another EPIC restoration story. If you have the time and wherewithal to do it yourself, go for it! _________________ erstwhile owner of just about every 924 variant ever made |
Han Solo
Posted: Wed Aug 19, 2015 12:14 am Post subject: |
It must have had a battery fluid leak to do that kind of damage to the galvanized metal. I've seen much, much worse on 914s and there is plenty of guys piecing those back together. I haven't done a lot of welding to the galvanized sheet metal but it certainly can be done. You're going to have to decide if the value of having a 931 with matching serial numbers is worth the time and effort to make those repairs. Looking at the floor pan, are there rust areas all the way through? If not, you may be able to strip, treat with marine clean and metal prep, then coat with POR 15. That's an epoxy enamel that will seal the metal and prevent further corrosion. I've got a 914 race car that I basically did that to every metal surface I could get to. _________________ -----HAIRY ANT NEST RACING-----
Collecting, racing and restoring Porsches for fun and negative cash flow.
-----Epic 914 race car build----- http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/767721-yet-another-rescue-porsche.html |
physicstim
Posted: Thu Sep 03, 2015 12:38 am Post subject: |
I'm going through with an ~epic-ish restore/repair.
I purchased a parts 931, that is not rusty! (though the exterior is... eeek!)
I have exposed all the rust I could find and will treat as per thread suggestions. I love to weld, but haven't done sheet metal before.
I'm in the process of pulling the head, I have the exhaust disconnected at the turbo and waste-gate.
Do I remove the fuel distributer thing to get at the timing belt? I'm stuck trying to get the t-belt shroud off... |
Knz
Joined: 05 Mar 2014 Posts: 105 Location: Sparrow Bush, NY
Posted: Thu Sep 03, 2015 4:25 am Post subject: |
| physicstim wrote: | I'm going through with an ~epic-ish restore/repair.
That is some pretty heavy rust you have there...
I just did the timing belt on my 931, and the cover is a huge PITA to get off. I took off the water pump pulley to get it out, and even then it was a struggle.
It will not be going back on, not without modification at least. _________________ 1980 931 (#185) for sale
1980 931 (#196) engine rebuild
1983 928S Project
1983 944 Summer Car
2002 BMW 525i Winter Car |
Han Solo
Posted: Thu Sep 03, 2015 12:19 pm Post subject: |
| physicstim wrote: |
I was able to get my timing belt cover off by removing air filter case, engine coolant hard line, alternator and AC belts. It was a little twisted when done but it's out (and not going back in). _________________ -----HAIRY ANT NEST RACING-----
Posted: Thu Sep 03, 2015 1:11 pm Post subject: |
| Han Solo wrote: | | physicstim wrote: |
I was able to get my timing belt cover off by removing air filter case, engine coolant hard line, alternator and AC belts. It was a little twisted when done but it's out (and not going back in). |
luckily cylinder heads, valves, followers, camshafts, pistons, rods, cranks, bearings and blocks are cheaper and easier to replace than a protective timing belt cover.
In other words, put the damned things back on and quite complaining, it may just save your expensive and hard to repair motor. _________________ Stefan
physicstim
Posted: Wed Sep 09, 2015 2:40 am Post subject: |
I needed to remove the water pump pulley to get the shroud off.
Any tips for the intake manifold? I need to replace all the vacuum lines, they have hardened and are brittle. Should I take the whole intake out as one piece or just disconnect and let is sit in the engine compartment while I unbolt the head?
Also, Does the distributor need to be removed prior to removing the head or can it stay in place?
Thanks,
Tim |
physicstim
Posted: Mon Sep 14, 2015 11:42 pm Post subject: |
Okay, Head is off! it looks like it's been repaired or replaced because the 1st piston definitely ran into a valve at some point in it's life.
I'll share pictures.
Also, my parts car has arrived! |
