a bit of help with gague lighting
MikesCoupeGT
PostPosted: Mon May 12, 2014 8:36 am    Post subject: a bit of help with gague lighting Reply with quote
So I have a problem seeing the speedo and when I use the signal light it flashes in the speedo. So I know it is wired wrong. I just cannot figure out how to get the gauges out of the cluster. Any idea's or assistance would be great. Thank you.
Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line
kcoyle
PostPosted: Mon May 12, 2014 8:44 am    Post subject: Reply with quote
Instructions found here worked for me.
http://www.clarks-garage.com/shop-manual/elect-06.htm
It's a PITA ( for me at least) to get the speedo cable undone. Everything else is pretty straightforward.
Push them from behind. They just slide out with some force, make sure to remove the speedometer cable first.
You can also swap the speedo and tach to have the tach front and center
brealytrent
PostPosted: Mon May 12, 2014 10:02 am    Post subject: Reply with quote
Don't even bother reading the speedo anymore, just use the tach. I know 3200 rpm is 60mph and call it good
1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman
