Email: cj48@qwest.net
Date: 23 Jun 2001
Time: 17:42:12Hello, I have a 1980 that regularly drains the battery down. I just bought a nice automotive multi-meter just to test the charging system. The reading between the battery posts is 12.5V with car on, accesories off and it will drain down if lights, wipers, etc. are on. The connection between ground(chassis) and the + post on the ignition coil reads 4.5V with car off 7.5V with car on. I have a haynes manual, but I'm still not sure about what the correct readings should be. Should I remove my alternator to have it tested or can they test them in the car?
Thanks,
Chris
