Email: dy15@yahoo.com
Date: 22 Jun 2001
Time: 23:56:32make sure you get some prep solvent that removes wax and all that compound that you put on, and make sure you get the entire area you will be clear coating. If not that'll mess with your adhesion too. As for the look you'll get the same look either way, but if done right the clear will last a hell of a lot longer.
