doiron_dancer75
Joined: 14 May 2009 Posts: 38 Location: New-Brunswick Canada
Posted: Wed May 15, 2013 2:36 am Post subject: Fuse box |
Ok so stupid question the # on my old fuse box is 171 941 813, I was wondering if a fuse box with # 477 941 813 would fit or if it's the same thing? Mine is toasted and I need a new one. _________________ '79 Euro 924 |
scm924s
Joined: 22 Oct 2010 Posts: 296 Location: Gloucester UK
Posted: Wed May 15, 2013 4:37 am Post subject: |
The 171 model is a VW Golf(Rabbit) part, the 477 no is the part listed for the 924. The Golf part will fit, but it depends on the suffix A to D. The two are probably essentially similar considering the 924 VW ancestry.
I was always under the impression that parts beginning 477 were VW parts anyway? _________________ 1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold |
Harm
Posted: Wed May 15, 2013 5:53 am Post subject: Re: Fuse box |
| doiron_dancer75 wrote: | | Ok so stupid question the # on my old fuse box is 171 941 813, I was wondering if a fuse box with # 477 941 813 would fit or if it's the same thing? Mine is toasted and I need a new one. |
I've always been tempted to switch these between the cars since I have both, and see if it will run.
It now seems you've already done what I had in mind?
Or is your wiringloom behind the fusebox a hack job?
VW
SKZ6141SHO
171 941 821A
171 941 813A
Toofah: Optical difference, the white rear plate.
477 941 813
Same amount of pins, same groups,
different purpose on some of the pins!
But if your wiring loom looks uncut, it would mean it is plug-n-play?
Kind regards,
Harm. _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
bear924
Joined: 26 Jul 2005 Posts: 95 Location: South West Queensland, Australia
Posted: Thu May 18, 2023 9:22 am Post subject: |
Reading old fusebox messages as I try to work out how to repair/ replace my fusebox.
When i compare the 171941813 vs 477941813 fusebox, the rear pin outs look substantially different between the two. I'm sure it's possible to make the 171 part work, woudl require substantial rewiring. This is a pity as you can purchase new VW fuseboxes ... no source found for new 924 ones at this stage. |
Mclaren924
Joined: 13 Oct 2021 Posts: 265 Location: Oceanside CA
Posted: Fri May 19, 2023 3:16 am Post subject: |
| bear924 wrote: | Reading old fusebox messages as I try to work out how to repair/ replace my fusebox.
Hey bud I got a good one laying on my desk right now if you're interested in buying? I'm in California but shipping wouldn't be too much. Send a dm for more info _________________ 1980 931 "Salt" Bucket wannabe racer (Dreaming)
bear924
Posted: Sat May 20, 2023 8:03 pm Post subject: |
| Appreciate the heads up Mclaren. I've ordered some parts to repair my exisiting fuse box. If it works I'll post the details on the board. If it fails, I might take you up on your offer. |
