I hope I haven't made a mistake here.
the_mad_electrician
PostPosted: Sat Mar 23, 2013 7:05 am    Post subject: I hope I haven't made a mistake here. Reply with quote
Drove to town today. Got back home temp gauge is in the red. I had my eye on it most ot the trip because it was on the high side most of the time. I'm hoping it is just air in the system when I turned the engine off it sounded like bubbling in the hoses. No time to investigate today.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Sat Mar 23, 2013 7:26 am    Post subject: Reply with quote
Flow test your rad.
emoore924
PostPosted: Sat Mar 23, 2013 9:44 am    Post subject: Reply with quote
and bleed the cooling system
PostPosted: Sat Mar 23, 2013 10:31 am    Post subject: Reply with quote
and do a compression test to see if you've blown the head gasket.
the_mad_electrician
PostPosted: Sat Mar 23, 2013 10:35 am    Post subject: Reply with quote
I figured it need bleeding.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Sat Mar 23, 2013 10:47 am    Post subject: Reply with quote
Bubbling noises always indicate a need to bleed the system.
StienbargerR
PostPosted: Sat Mar 23, 2013 1:47 pm    Post subject: Reply with quote
+1 on a compression test.
I once threw a belt minutes from home in freezing temperatures. Car started to overheat. I figured since it was so cold outside it wouldn't be a big deal. When I got home I heard bubbling in the hoses as well. Long story short- It warped the head.
1978 924 NA
-250lb lowering springs, Euro Pistons
the_mad_electrician
PostPosted: Sat Mar 23, 2013 11:47 pm    Post subject: Reply with quote
I have a spare head. I had told someone I was going to sell it to them but if my head is warped I might just have to piss someone off. Sorry
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Sun Mar 24, 2013 7:47 am    Post subject: Reply with quote
Most of the time the head can be machined back to specs.
