Fuel pressure gauge
PostPosted: Sat Nov 17, 2012 5:39 am    Post subject: Fuel pressure gauge Reply with quote
a friend gave me this gauge:
http://www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=19
Is it possible to hook it up constantly ? And if yes, where do I hook it up ?
PostPosted: Thu Dec 06, 2012 6:46 am    Post subject: Reply with quote
Nobody ?
I saw the GTR has a feul pressure gauge also.
PostPosted: Thu Dec 06, 2012 6:35 pm    Post subject: Reply with quote
looks like it's a mechanical gauge, tee into main feed line from pump, somewhere around the fuel filter or fuel dissy to monitor system pressure...
I'd want to make damn sure there's no leaks running into the cabin with a mechanical gauge though!!!
PostPosted: Fri Dec 07, 2012 12:28 am    Post subject: Reply with quote
Comes up as digital with remote sender when I click the link from here.
Obviously you could look at either system or control pressure, or with an additional sender and a switch it might be wired to show either one with a flip of the switch.
Pricey product - you may owe your friend some beers.
This illustration shows where system and control pressures exist -
<click for larger>
PostPosted: Sat Jan 19, 2013 6:49 am    Post subject: Reply with quote
The sensor is a in a T piece.
Will the black arrow be the best place for the fuel pressure sensor ? My fuel pump is new so I trust him.
PostPosted: Thu Jan 24, 2013 2:17 pm    Post subject: Reply with quote
No, there you'd actually be reading the pressure of the return flow back to the fuel tank.
PostPosted: Fri Apr 08, 2016 12:52 am    Post subject: Reply with quote
Last Smooth Dog post, three years ago...
Anyone been in touch with him?
