Dual gauges pod, What do you think?
Dual gauges pod, What do you thing?
That’s cool, would buy
86%
 86%  [ 13 ]
That’s dumb, would never buy
13%
 13%  [ 2 ]
Total Votes : 15
PostPosted: Mon Oct 29, 2012 6:49 am    Post subject: Dual gauges pod, What do you think? Reply with quote
{edit} I mean "think" not "thing" {edit}
I would like to get your opinions and interest on a little something I’m working on.
In fact, I started working on this last winter and then put it a side because I was to busy with the 924/944 GTS headlight.
I tried to replicate the shape of the factory one below the grill.
If there is enough interest, I could spend some time on this during winter and try to have it ready for next spring.
It would only be available in black and go for around $65 shipped to CAN and US.
This is only a rough estimate and not a confirm price.
Let me know what you thing, beside the little trimming problem I had
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
daniel
PostPosted: Mon Oct 29, 2012 8:35 am    Post subject: Reply with quote
Looks good, would buy one if you could do brown
1989 944 Cabriolet
!tom
PostPosted: Mon Oct 29, 2012 9:55 am    Post subject: Reply with quote
Wow!
That's the first one I've seen that doesn't look totally tacky.
If I had a need for one (which I don't currently), that one would be the only one on my list.
78 924 NA
5-lug
D Hook
PostPosted: Mon Oct 29, 2012 10:48 am    Post subject: Reply with quote
How hard would it be to angle those towards the driver about 15°? Sort of like the early 240Z look? They'd be easier to see and give more accurate reading for the driver.
'80 924 n/a SOLD
PostPosted: Mon Oct 29, 2012 11:30 am    Post subject: Reply with quote
They make angled rings you can add behind the gauges to tilt them to your needs.
I'd be concerned about visibility in direct sun, but that's easy enough to test.
Any thoughts about adding another gauge in there or selling them blank to accommodate whatever we might want to mount there?
924-76
PostPosted: Mon Oct 29, 2012 7:27 pm    Post subject: Reply with quote
D Hook wrote:
How hard would it be to angle those towards the driver about 15°?...
I will check if I can do something about that.
I have a set in the mail, I will test fit them when they get here.
fiat22turbo wrote:
Any thoughts about adding another gauge in there…
Do you mean a third one or a different size/diameter one?
No room for a third one.
fiat22turbo wrote:
…or selling them blank to accommodate whatever we might want to mount there?
Sure, I can sell them uncut or 1 hole cut and 1 not, so you can mount what you want.
I might be able to sell them without the 2 round shapes, flat surface to mount a GPS or whatever.
1980 931S
924-76
PostPosted: Sat Nov 03, 2012 6:43 am    Post subject: Reply with quote
I still have to work on one of the mould as I’m not 100% happy with the fitment but it’s getting there.
If this come trough, you could order one or both pods uncut, I left one pod uncut to show you what it looks like. This was point out to me by a member.
This way you could mount a manual boost controller, shift light, different size gauge, etc…
1980 931S
924-76
PostPosted: Sun Nov 04, 2012 11:14 pm    Post subject: Reply with quote
This thing might be ready before spring
I still have some tuning to do on the moulds, but now the bottom of the pod reaches the edge of the opening.
Just to be clear, only the pod will be for sale, gauges will not be included
Have you notice the time on the clock?
1980 931S
PostPosted: Sun Nov 04, 2012 11:34 pm    Post subject: Reply with quote
How about one in carbon fiber?
924-76
PostPosted: Sun Nov 04, 2012 11:46 pm    Post subject: Reply with quote
I’m afraid that’s out side of my skill set
But you could use something like this on the top of it: http://www.ebay.com/itm/Car-Surface-DIY-Stick-Black-3D-Carbon-Fiber-Vinyl-Sticker-63cm-x-200cm-25x80-/181013781024?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a25431a20&vxp=mtr
1980 931S
BionicBalls
PostPosted: Mon Nov 05, 2012 8:42 am    Post subject: Reply with quote
So you would glue the panel in?
1980 924 NA
1982 931
924-76
PostPosted: Mon Nov 05, 2012 8:59 am    Post subject: Reply with quote
Similar discussion on Rennlist
thirdgenbird wrote:
Will the finished unit have pins to fit the oem mounting points?
924-76 wrote:
I haven’t decided how to mount it yet
I tough about using the OEM mounting point or maybe just using a bit of black adhesive / sealant.
It wont need a lot of force to hold it in place
1980 931S
john h
PostPosted: Mon Nov 05, 2012 1:10 pm    Post subject: Reply with quote
They look really good - I was thinking of doing a similar thing but since some one else has done it and it looks neater than what I'd end up with. I think I could be keen in one - just post to New Zealand could be the killer ( a brown one would be nice as well)
Remember a Porsche is not just for Christmas,
if you take it to pieces slowly it can provide anguish all year long!
JasonO
PostPosted: Mon Nov 05, 2012 2:39 pm    Post subject: Reply with quote
John we could split the postage!.
john h
PostPosted: Mon Nov 05, 2012 4:49 pm    Post subject: Reply with quote
Good idea
