Engine build advice needed
Andrew NZ
PostPosted: Sat Oct 20, 2012 8:07 am    Post subject: Engine build advice needed Reply with quote
Hi, as most of you know I've had a rotary engine in my 924 for the last 4 or 5 years, so I've lost track of what people are doing to their 924 engines these days!
I have a mate (Terry) who's wanting to build up a new engine for his 924, which his wife uses in classic racing here in New Zealand. They've run it as a completely standard rebuilt engine for the last few years, but are wanting a bit more power now.
Requirements are reliability and probably torque above hp, as the main track they compete at is quite hilly. I've skimmed through some of the posts recently about stroked cranks etc, and wonder if this might be the best option for improved torque? Also interested in the present thoughts about using a turbo head verses the big valve head modification.
We'd appreciate any suggestions people can come with, as well as links to related posts, as the plan is to show this thread to their engine builder when they're ready to go. I usually get my parts through Ideola, so any comments on the bits we can get through him would be greatly appreciated as well.
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
PostPosted: Sat Oct 20, 2012 9:14 am    Post subject: Reply with quote
Hi-comp, stroked with efi and ITBs.
Andrew NZ
PostPosted: Sat Oct 20, 2012 7:11 pm    Post subject: Reply with quote
Reading through his class rules, EFI might be hard to push through, but everything else is pretty free. Probably have to look at carbs, as I'd imagine the CIS will be a bit restrictive??
Andrew
1977 RX924 race car
the_mad_electrician
PostPosted: Sat Oct 20, 2012 9:58 pm    Post subject: Reply with quote
CIS may be restritive as far as air flow goes but it has better fuel control than a carb/carbs.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Sun Oct 21, 2012 1:40 am    Post subject: Reply with quote
Can you swap to a different Audi motor? Might be a good opportunity to move to a 2.3L 20-valve 5-cylinder Audi motor (non-turbo) Should be about 170hp and can go up from there easier than the 2.0L 4-pot.
Andrew NZ
PostPosted: Sun Oct 21, 2012 4:32 pm    Post subject: Reply with quote
I think they have to (and want to) stick with the 924 block. It was actually originally a turbo, but had an NA engine fitted before he got it - pretty sure he wants to stay NA now too.
Andrew
1977 RX924 race car
932kiwi
PostPosted: Mon Oct 22, 2012 9:44 am    Post subject: Reply with quote
I thought Terry already had the turbo head on his car.
(But I have only seen his car once so I'm probably mistaken)
Andrew NZ
PostPosted: Mon Oct 22, 2012 10:57 am    Post subject: Reply with quote
No, totally stock NA at the moment. He's got my old block, so will build the new engine based on that and then swap them over.
Andrew
1977 RX924 race car
Robert Hooper
PostPosted: Mon Oct 29, 2012 10:30 am    Post subject: Reply with quote
Hi Andrew,
I used to race my car in Bridgestone class E, engine was blueprinted and balanced.. This made a huge difference, Head was polished and match ported to the intake mainfold, I made 138hp and the flywheel using a standard header..
I still have the head off this car and am not using it if your mate is interested, i would also suggest putting in a piper cam and going to side drafts... I also have a manifold in the garage for this if interested...
Also have a lhd header for the engine, could be modified if wanted to use it...
I am not needing this as converted to 968 engine...
Cheers
Rob
1982 924 Race Car
1981 931 Road Car
Andrew NZ
PostPosted: Mon Oct 29, 2012 8:04 pm    Post subject: Reply with quote
Robert Hooper wrote:
Hi Andrew,
Cheers
Rob
Sounds interesting - I'll check with Terry and send you a message!
Andrew
1977 RX924 race car
PostPosted: Fri Feb 08, 2013 3:07 am    Post subject: Reply with quote
Andrew
Suggest you look here for some ideas:
http://www.924board.org/viewtopic.php?t=36293
This approach could be used with a lot of the components that Robert mentions in his post. Also, you can build a really nice non-stroked high compression setup using an NA head with US-spec S1 or S2 931 pistons, which are cheap and plentiful. The only drawback is that it doesn't increase displacement because you can only go with 86.5mm and no add'l stroke.
If you want to get some ideas of the different options, take a look at my compression ratio calculator:
Ideola's Cheap-a$$ Long Rod High CR Stroker
OEM Hybrid: NA head with US S1 931 pistons
OEM Hybrid: NA head with US S2 931 pistons
Andrew NZ
PostPosted: Fri Feb 08, 2013 7:43 pm    Post subject: Reply with quote
Andrew
Hi Dan, have been following that thread with interest! Terry has bought the carbs and light weight flywheel off Rob, and is starting to plan ahead for the build. His gearbox has just finally given up the ghost, so will be oin touch shortly to order some parts from you once his mechanic has stripped the box down.
Thanks,
Andrew.
Andrew
1977 RX924 race car
john h
PostPosted: Fri Feb 15, 2013 9:16 am    Post subject: Reply with quote
I also have a worked head with a modified cam and I think it's got a piper adjustable cam pulley, that can be purchased.
It came with a 924 that had run it's bearings. Head is OK will check with the previous owner as to what the cam grind is etc. I was going to put it on my daughters engine but decided to leaveher car standard and not sure how the cam would go with the auto
Remember a Porsche is not just for Christmas,
if you take it to pieces slowly it can provide anguish all year long!
porscheboy79
PostPosted: Thu Mar 07, 2013 9:00 pm    Post subject: Reply with quote
John h
are you interested in selling it to an Aussie if they don't want the head and cam.
Shane.
79 924. 100kph + wall at Mt Panorama = Gone.
77 924 SPIRIT project for racing.
