924 Valve Adjustments
PostPosted: Tue Jun 12, 2001 9:20 am    Post subject: Reply with quote
Email: vances@mwonline.net
Date: 12 Jun 2001
Time: 09:20:03
I have an '82 924 with about 74,000 miles. When I bought it there was some clicking coming
from the area of the cam cover. I suspected that the valves needed to be adjusted and I did that.
Now there is still some noise (although somewhat less). The noise seems to become louder
after the car has warmed up.
When I adjusted the valves I did it with the engine cold. Was that a mistake? Are you supposed
to adjust the valves with the engine hot? Also is it possible that the noise is from the injector
and not the valve.
PostPosted: Tue Jun 12, 2001 2:54 pm    Post subject: Reply with quote
Email: porsche
Date: 12 Jun 2001
Time: 14:54:48
I did mine 924 cold also but what you can do is recheck and recheck and try it warm check if there on iused haynes also.
PostPosted: Tue Jun 12, 2001 4:45 pm    Post subject: Reply with quote
Email: Eric.lynch@itt.com
Date: 12 Jun 2001
Time: 16:45:18
Typically once a car is broken in you want to check them when the engine is warm.
But wanted to ask. How was the wear on the cams and followers?
The noise might be insufficient lubrication, or it might be totally normal. Anyway just
wanted to note that you should closely inspect the wear any time you have the cover off
also inspect the plastic elbow at the oil tube feed end to make sure it has the proper
fit and not leaking.
There are many here that have replaced this part, and or used sealant to get a good seal
for proper cam lubrication.
Eric
PostPosted: Wed Jun 13, 2001 3:51 pm    Post subject: Reply with quote
Email: david.c.russell@lmco.com
Date: 13 Jun 2001
Time: 15:51:09
Is the plastic elboe just an NA part, or does the turbo use it to.
Date: 13 Jun 2001
Time: 15:51:43
PostPosted: Wed Jun 13, 2001 4:20 pm    Post subject: Reply with quote
Email: l_porsche@hotmail.com
Date: 13 Jun 2001
Time: 16:20:08
its on teh NA and the turbo, its a black plasitc elbow, some dealers you can get it seperatly from teh oil tube, at my dealer the guy told me it was 200 some dollars for the elbow, poor little man, i felt sorry for the poor little man on the phone after i stopped laughing at him.
PostPosted: Thu Jun 14, 2001 12:00 am    Post subject: Reply with quote
Email: jfurst81@hotmail.com
Date: 14 Jun 2001
Time: 00:00:29
<its on teh NA and the turbo, its a black plasitc elbow, some dealers you can get it seperatly from teh oil tube, at my dealer the guy told me it was 200 some dollars for the elbow, poor little man, i felt sorry for the poor little man on the phone after i stopped laughing at him.>
That's interesting. I'm starting to see why you have such a bad attitude. I bought that part, at the dealer, for $4 or $5. Maybe your closest dealer is a scam artist?
Part number is 052 115 707
Jon Furst
'81 931
PostPosted: Thu Jun 14, 2001 11:44 am    Post subject: Reply with quote
Date: 14 Jun 2001
Time: 11:44:05
Demand and supply, california has a ton of people with 931s, Edmonton Alberta Canada has none, demand is low, prices go up.
Didn't i tell you what my dealer does with teh new cars on the lot? They autocross them during lunch and after hours and sell them as new cars.
